Question about Apple iPhone Smartphone
Lock up after trying to install 3.0
I have tried resetting and restoring but nothing works. When trying to restore I get error message 1604. Any ideas on how to fix?
There are a lot of suggested solutions on different forums for the 1604 (including on the Apple support site) - most blame a faulty / corrupted itunes and suggest reinstalling, or blame the USB port you're using and suggest either trying a different port (ideally at the back of your HD) or different computer. None of those things worked for me when it happened to me. My issue was that the 'preparing to restore' phase of restoration became looped and eventually it crashed citing error 1604.
However, there was a solution at: http://daggle.com/iphone-upgrade-fail-701 which did work for me.
For convenience:
1. Start the restore process (whatever way you can).
2. When it seems to be stuck in the loop (and possibly your iPhone just shows a blank screen) use CTRL+ALT+DEL and end task to kill the iTunes application.
3. Restart the restore process.
Posted on Jun 23, 2009
  • Apple Master
  • 4,338 Answers
Try these resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 18, 2009
Okay I have been using my HP G61, for a while now. I bought it 3 months ago. And I used it for college everyday. I used it last night before I went to sleep. I've closed it and left it charging all...
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 28, 2013 | Computers & Internet
Tried to update now ipod doesn't work at all!
download lastest ipod lastest firmware from http://www.felixbruns.de/iPod/firmware/
restore your ipod using that firmware.
here is howto do it tutorial
http://iphoners.org/shift-restore.itunes/
Dec 27, 2011 | Apple Ipod Touch 4
I dropped my iphone 2g 16GB in a toilet bowl last month. I managed to dry it out but currently having problems in restoring it. ITunes just keep giving me errors like 1611, 1604, 23 and so on. I tried to...
Hey Chee, Usually an iphone with liquid damage may cause damage to internals that may go unnoticed if it is able to work. Depending on the error message you get when restoring with itunes may mean different things.
  • 1604 is just to check your usb cable to make sure its directly (not through a hub) connected to a usb 2.0
  • 1611 and 23 are usually hardware issues that cannot be solved with a restore
Mar 08, 2011 | Cell Phones
Downloaded music to itunes last night, when I tried to sync with ipod nano, it took ages, and then came up with error message on computer saying something like "cannot locate disk" and then I tried again...
It let you restore it and you still get "unable to sync as playlist on ipod has changed"? I think that the restore was an erase and install and complete re-Sync of it. I think you need to try the restore function again and make sure it completely re-syncs before trying to do anything with it.
Sep 10, 2009 | Apple iPod nano
Error 1604 and Kernel Panic
confirm that your firmware is compatable with your iphone.
if you have a 2G the firmware should start with 1.1 if you have a 3G the firmware should start with 1.2
apparently unlocked or jailbroken phones with the wrong firmware will brick in this manner.
not to worry, your not the only one.
do a web search for error 1604 and you will see solutions such as this below.
  • Problem: I cant restore my custom firmware. I just get error 6, 1, 2, (something low).
    Solution: This has multiple causes. Generally, you are not in DFU mode. See DFU guide. Winpwn solution after ruling out the above: Delete the device file (x12220000_4_Recovery.ipsw) in your iTunes folder. (Search for the file). This can also be caused by using the incorrect firmware image (a 3g on a 2g for example).
  • Problem: I am in DFU mode and I just get error 1604, 1602, 1601 (some 160x). I am pulling my hair out! What do I do?!
    Solution: This one sucks. There’s no single answer for it. Here are some possible suggestions:
    • Validate you are using the correct firmware. You can get this if you are using an incompatible firmware (3g for 2g for example).
    • Restart your computer and try again.
    • Try another computer
    • Try switching USB ports
    • Uninstall and reinstall iTunes 7.7
If you are not able to get out of DFU mode even after trying one of the above fixes, click here to follow the comments on BigBoss’s website.
Apr 17, 2009 | Apple iPhone 3G Black Smartphone
My i phone is frozen when i try to restore it comes up o the screen as there is an error 1604
for this kind of error, you will have to resort to restoring the phone. just follow the link below to solve your problem.
http://support.apple.com/kb/TS1275
hope you get this working
Aug 17, 2008 | Lands Phones
Will show avaliable wireless networks but won't connect
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
if the Issue presist then you need to try System restore
If Windows XP starts loadTOCNode(3, 'moreinformation'); 1. Log on to Windows as Administrator. 2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts. 3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. 4. On the Select a Restore Point page(try the date 2 dats prior it was working or the First Bolded Date of that month), click the most recent system checkpoint in the On this list, click a restore point list, and then click Next. A System Restore message may appear that lists configuration changes that System Restore will make. Click OK. 5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. 6. Log on to the computer as Administrator. The System Restore Restoration Complete page appears. 7. Click OK.
Aug 09, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Can't Restore iphone
Well since you have and unlocking iPhone software you can restore your iPhone because the factory settings of the origanal iPhone have been removed.
Thank you, Apple Care Technical Support
Jul 03, 2008 | Apple iPhone Smartphone
CARTRIDGE WONT ALIGN
The following error message appears on the LCD panel1.gif on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected.
Feb 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
WINDOWS MEDIA PLAYER 10 WILL LOAD BUT WILL NOT RESPOND WHEN I WANT TO GO TO LIBARY OF STORED MUSIC. TRYED UPDATES, RELOADING, REINSTALLING , NOTHING WORKS , NO ERROR MESSAGES EITHER, PLEASE HELP...
Reboot system in safe mode. It will ask to restore to previous restore point. Try to select restore point before you have installed windows media player 10. Reboot the pc and then try to install media player 10. It will be better if you run scandisk to fix file system errors. Or you can use any tools for fixing file system & windows system registery error like System Mechanic, Symantec Windoctor.
Thanks,
Vksr.
Oct 13, 2007 | Computers & Internet
Apple iPhone Smartphone Logo
482 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
