Question about 3Dconnexion CadMan 3D (114090001) Trackball
Error message 17- Axis doesn't reach imposed speed
HOW FAST PRE MILLE DOSE THE EARTH SPIN
1,040 mph
An object on the Earth's equator travels once around the Earth's circumference. This is about 24,901 miles (40,075 kilometres) per day. To calculate speed, Mr Kadish divided that distance by 23hr, 56m, 4s to reach the figure of 1,040 mph.28 Jan 2014
How fast are YOU spinning on Earth's axis? ' Daily Mail Online
www.dailymail.co.uk/sciencetech/article.../How-fast-YOU-spinning-Earths-axis.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=how%20fast%20does%20the%20earth%20spin
Dec 01, 2016 | Cars & Trucks
Persistent Error 86:01
Oh my throw it away, too much you have tinkered with its not worth the headache
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Janome mb4 embroidery machine-when carriage resets it goes all the way to the right
It sounds like your x-axis sensor is either broken or malfunctioning. When the machine initializes, this sensor tells the machine when it has reached the furthest point in it's range of motion. If it is not working properly, the carriage will extend past it's normal range, and stop when it physically cannot move any further. After a specified amount of time the x-axis motor shuts off, and an error message will appear. For a certain diagnosis and repair, it would be best to take your machine in to a Janome dealer.
Mar 15, 2014 | Janome MB4 Four Needle Embroidery Machine
What is the meaning of the error message "invalid axes"
This is problem with graphing differential equation. Invalid Axes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image
Feb 08, 2012 | Texas Instruments TI-89 Calculator
What is the meaning of the error "invalid axes"?
This is problem with graphing differential equation. Invalid Axes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image:
This graph represented differential system of equations y1'(x)=y2(x), y2'(x)=-y1(x) for initial conditions y1(0)=0, y2(0)=-1.Finally, x axes=y1(x) and y axes=y2(x)
I have a dell 755 that the CD drive won't play certain CD's. It is not the CD because it plays on other machines. Some CD's will play just fine. Get's the error message Unable to Access Drive D tr
it depends on the files on the cd ...they might require a certain software to be installed in order to be read..for example the player may not be able to read mp4 without a codec installed ..or vcd (video cd ) to need a dvd player installed or a player that supports video cd and dvd-es..Same way for other file types...or ...certain speeds being imposed on writing ..and your cd drive to be unable to read them on those speeds..
Nov 09, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
The line of the graph appears but theres no x or y axis...what do i do to get it normal? does it have something to do with the mins and maximums? HELP!
It could. If the x range doesn't include x=0 then the y axis will not show. Likewise, if the y range doesn't include y=0 then the x axis will not show.
Jun 21, 2011 | Texas Instruments TI-82 Calculator
Brother pr 600 has x axis possition error message.
In most cases customer were emb. bags when or after you get this error message, there is a sensor under the x-axis; horizontal arm; that gets hit and breaks you can try to get a dealer to sell you the sensor and repalce it yourself its really easy, one screw on the side of the x-axis cover and it lifts and slides off and one screw for the sensor plus two flexible flat cables plug into it
May 05, 2009 | Husqvarna Designer I
Error message 388
Hi! Error 388 means the local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames.
If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Use the link below-
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153695&prodTypeId=18972&prodSeriesId=1153695&objectID=buu02549
Jan 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
3Dconnexion CadMan 3D (114090001) Trackball Logo
Top 3Dconnexion Computers & Internet Experts
David Payne
David Payne
Are you a 3Dconnexion Computer and Internet Expert? Answer questions, earn points and help others
