The conflict with the Azeri in Armenia is based largely on ethnic differences
Are there many Asian American pilots in the US? Would it be hard for them to be pilots in the US?
Airlines from the U.S. contract pilots based on their qualifications and the right to work in the U.S. It is ilegal to discriminate against race, ethnic background, veteran status.
Jan 04, 2017 | Aircrafts
IP Conflicts
I would try a different port with a new cable. IP conflict should be noted by the PC / node. You could ping the IP in question with the -a switch to resolve DNS name. You could also run a traceroute from the command prompt to help identify what drop if failing / timing out.
Jan 18, 2013 | Dell Computers & Internet
I need unlock code for nokia 1616-2 Orange Armenia operator IMEL354303045778651
For good place to get the unlock code for Nokia model, visit this site www.onlinegsmunlock.com/nokia-1616/rs7wp9, it provides step by step instructions and easy ways to unlock the phone lock network ..... while for the unlock code you have to give some information about the mobile site that is your IMEI number, network and country lock, then in a short period you can get the code ...
Sep 08, 2011 | Nokia 1616 Cell Phone
What is your hobby
Hi!
My hobbies are listening to music, watching TV, computers and helping others with technical problems... I also like to cook! :)
Pelu.
Feb 05, 2011 | Audio Players & Recorders
Conflict message
if u have 2 PCs connected to the hub/router then you must specify the IP address in Network Connection wizard..../ LAN properties / TCP-IP setting Tab......set each PC different....IP address
say like this.....
192.168.1.3 for 1st PC
192.168.1.5 for 2nd PC
the rest of the settings is based on you internet service provider
this will work....
Jul 15, 2010 | NetGear EN104 Networking Hub
Laptop hasn't been used in a while. I turned it on and got an error. Resource Conflict - PCI Network Controller How do I fix this? Running Win98
  1. Go to Start » Settings » Control Panel to launch the Control Panel window, and then double-click on the System icon. In the System Properties window, click on the Device Manager tab at the top of the window.
  2. If the operating system has detected a resource conflict, it will indicate this with a special symbol (a black exclamation mark within a yellow circle) next to the name of the device with the resource conflict:
  3. Single-click on the device with the resource conflict to highlight it and then click on the Properties button at the bottom of the window. This will bring up the Properties window for your PCI Network Controller. Select the Resources tab. You should see a screen similar to the one below:
  4. Deselect the Use automatic settings checkbox, and single-click on the resource with the conflict to highlight it.
  5. You may need to change the entry in the Setting based on menu ring to a different basic configuration, in order to disable the use of certain resources. The basic configurations range from a "base I/O address only" setup to various combination's of base I/O address, IRQ, and DMA. (Note: some devices only have one basic configuration.)
  6. Click on the Change Setting... button to bring up the editing window for that resource. You will be able to cycle through the available resource settings for your system. If Windows 98/95 is aware of any devices that are already using that setting, you will be informed of this in the Conflict information area at the bottom of the resource editing window.
Jan 26, 2010 | IBM ThinkPad A21m 2628 Notebook
Body fat scale Question
Like all body fat tests, body fat scales don't actually measure your body fat percentage. They determine your body density. The examiner (or the scales) then uses a formula to calculate body fat percentage based on body density. These formulas just predict your body fat. Unfortunately there is no one formula that accurately predicts body fat for the whole population. Differences in age, gender, ethnicity, body size, and fitness level all have a significant affect on the results. Well, whether body fat scales measure your "true" body fat percentage or not doesn't matter! As long as they can accurately monitor changes in your body composition over time, that's all you need.
Aug 27, 2008 | Detecto DR150 Low Profile Digital Platform...
Different Bit shanks
Those with larger bit shanks can hold larger blades. For large joinery cuts, buy a router with a large bit-shank diameter.
Aug 27, 2008 | Dewalt DW618PK Factory Reconditioned 2 1/4...
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
