Question about Mtd Cub Cadet 48 In 22 HP Kawasaki Engine Dual Hydrostatic Z Force S Zero Tur
How to reset the change oil light on a white zt42 mower
Engine is equipped with safety oil shut off need to reset after oil change How?
Glen, I think the oil change light may reset it self after a few hours, but as far as a reset, I am not sure of. The actual oil sensor in the engine may be at fault, you can try cleaning, testing, and reinstall or just replace. Check the attached links,instruction and guides, ro search your self using, Google search your make and model# manual. Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to reset the Oil Change Message
Outdoor Power Equipment Small Engine Lawn Mower Repairs Troubleshooting...
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1261829
May 23, 2016 | Garden
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Troy Bilt colt ZT42 PTO is not working
pto going out it over heats the windings and goes out till its cool enough to start run till it goes out replace it then
Aug 31, 2014 | Garden
After running for a while my Troy Bilt RZT tractor Colt ZT42 PTO stops working
pto going out or stater going out run till it does then replace i the red neck saya it the pto replace if you cant live with it till burns out
Aug 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
Jul 06, 2009 | Garden
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Mtd Cub Cadet 48 In 22 HP Kawasaki Engine Dual Hydrostatic Z Force S Zero Tur Logo
42 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
