Question about Hunter 20456 The Brighton Ceiling Fan
NEED REPLACEMENT CANOPY BRACKET
Hunter Fan 20456380
jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
  • 351 Answers
SOURCE: The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Posted on May 06, 2010
  • 57 Answers
SOURCE: How does the receiver of
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Posted on Jan 23, 2011
amit kashyap
  • 186 Answers
SOURCE: I have 3 Hunter fans remote control and the
HI,
PLEASE GO TO THE GIVEN LINK .
THE LINK IS :-
http://www.hunterfan.com/
I HOPE THIS WILL BE HELPFULL TO YOU.
PLEASE DON,T FORGET TO VOTE ME.
GOODLUCK.................
Posted on Feb 01, 2011
canwoodjc
  • 3301 Answers
SOURCE: where can I find hunter replacement blade
this link might help you,, without a model number I can't look anything up for you ,,,, but they may be able to help you http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/
Posted on Oct 01, 2011
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
Where does the receiver go on a model 59016 hunter fan
It goes in the canopy cover at the ceiling. Slide into bracket.
Aug 01, 2014 | Hunter 52" Ceiling Fan With Light And...
Can't fit remote receiver into canopy of Hampton Bay ceiling fan.
Hang the fan and slip the receiver between the space above the hanging ball on the fan. Hunter remote might not work.
Mar 15, 2013 | Dryers
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
How does the receiver of the Hunter model 21871 ceiling fan attach to the canopy? There are two things on the receiver that seem as though they should connect to the canopy with slots but no slots in the...
Jan 23, 2011 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Mar 02, 2010 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Reprograming Ceiling fan remotes
You need to find the dip switches or jumper blocks on posts on the remote and on the fan. As for the receiver, usually they are in a separate unit that slides into the hanger bracket that attaches to the ceiling inside the decorative canopy cover, otherwise they should be visible if you are looking down onto the top of the motor without having to open any kind of access. And as for the remote, you should be able to access them through the battery compartment. just make sure the codes match.
Sep 05, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan removal
first- remove the fan blades, next around the canopy there are three screws. remove these and the canopy will drop down. the fan will be hanging on a semi round ball in the mounting bracket. the circuit board should be accessible above the bracket.
Aug 18, 2007 | Hunter 20531 Vista Brushed Nickel Ceiling...
Dryers Logo
23 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
