Wep key entering
How or in what order do i enter my wep key and do i need spaces in between the pairs
  • kfuture1x Apr 24, 2009
    my laptop was stolen a few wweks ago,i just went and bought one from the pawn shop but all the hardware is missing meaning it has no ethernet adapter nor sound card how do i replace this without it being to exspencive?
    Scholar:
  • 54 Answers
Network key is very case sensitive no spaces should be there even if there are spaces or a dash when you see it in the router page but when you are entering it in the laptop it should be continous,and make sure you make a note whether the alphabets are in upper or lower case..since it is case sensitive it need to be entered exactly the way it is setup in the router..
vedhick
Posted on Feb 07, 2009
We are trying to sign on to our home network but the WEP key, after entering, keeps saying settings are invalid. What exactly is the WEP key? What do we need to do?
Are you trying to connect to your internet connection for wireless? If it is, the WEP key is the password that you set up for your wireless device so that devices that can see the your wireless network will be able to connect by entering the right WEP key. If you didnt change the WEP key of your modem or router, then the default WEP key will be found at the back of your device, but if you had changed it before then, that's the WEP key that you need to enter.
Sep 05, 2011 | Nintendo DSi Black Console
Tip
How to setup WEP on a Belkin N1 Wireless Router F5D8231-4 v5000 1. Log into the...
1. Log into the router. To do this you will need to open your web browser and enter http://192.168.2.1
Note If you change the default IP address then you will need that address to log into the router. Normally it is the Gateway IP. You can check this by opening CMD via the Run command window. Once it is open then type ipconfig and hit enter.
2. Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
3. Next you will click on the Wireless heading then Security in the left hand column.
4. Select “128-bit WEP” or “64-bit WEP” from the drop-down menu.
5. Next you can enter your WEP key manually by typing in the hex values in the space provided, or you can type a passphrase in the “PassPhrase” field and click “Generate” to create a WEP key from the passphrase. Click “Apply Changes” to finish.
Note a hexadecimal key is a mixture of numbers and letters from A–F and 0–9. 64-bit keys are 10 digits long and can be divided into five two-digit numbers. 128-bit keys are 26 digits long and can be divided into 13 two-digit numbers.
At this point you should have your WEP setup. When you connect your computer to the wireless router you will be prompt for the WEP key you just set up.
on Mar 25, 2010 | Belkin (F5D8231-4) Wireless Router...
My WEP key changed and I need to enter the new one into the ps3 in order to get online. How do I do this?
In order to get to the correct screen to enter your wireless security key follow the steps below,
Turn on your playstation and go to Network Settings under Settings in the main menu.
Select Internet Connections tab and then select Yes when it gives you a disconnect warning.
Select Easy on the next screen then select Wireless for your internet connection.
Select Scan to bring up all available access points and select your home wireless access point.
Select your security settings and enter in your WEP key. Save your settings.
Afterwards, it is always good to select test connection.
Regards,
G33k
May 11, 2011 | Sony Playstation 3 (PS3) Console
How do we find the WEP key for my WGR614v9
Configuring WEP:
  1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  4. Select Wireless Settings from the Setup menu in the left-hand navigation bar. n101675_image001.jpg
  5. Under Security Options, select WEP (Wired Equivalent Privacy).
  6. From Security Encryption (WEP) > Authentication Type, select Automatic.
  7. From Security Encryption (WEP) > Encryption Strength, select 64-bit or 128-bit. NOTE: You will need to configure your wireless computers with the same setting.
  8. From Security Encryption (WEP) Key, select Key 1 and enter a key.
    • Note: WEP keys are entered in hexadecimal digits, which are any combination of 0-9, A-F.
      • If you selected 64-bit under Security Encryption (WEP) > Encryption Strength, then enter 10 hexadecimal digits for your key.
      • If you selected 128-bit under Security Encryption (WEP) > Encryption Strength, then enter 26 hexadecimal digits for your key.
    • SAVE or KEEP NOTE of these values - they will be required to connect wirelessly to your network.
  9. Click Apply to save the settings.
Feb 21, 2011 | NetGear WGR614 Wireless Router
How can I find or reset the security key on my D-link WBR-2310 wireless router?
In order to find the wireless security password of your Dlink wireless router G WBR-2310 , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.0.1 and hit enter.
2. You will be logged into the D-Link router setup page .
3. Under the SETUP tab, in the left hand side, click on WIRELESS SETTINGS? you will find Wireless security Mode under which you can find the password for the wireless settings.
Good Luck!
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
I have Samsung WEP 495 Bluetooth headset. I have lost its customer manual. I need its password for pairing it with my NOKIA Mobile handset. Please help me out. Regards and thanks in advance.
The default pass key is 0000 but before entering the key in your mobile, you'll have to enter your wep 495 into a pairing mode which you can do by pressing & holding the call button till the led gets stable.
Thanks & Regards
Vaibhav Y. Dhakate
Oct 29, 2010 | Cell Phones
How do i find my wep key
for finding wep key you willhave to access the firmpage of router then under advance section where you have entered wep key uncheck the option hide wep key it will display the key to you or you can also enter a new key if you want,.
in order to access the fism ware of the router please type 192.168.1.1 in the address bar it will display the firm page of the router.
Sep 05, 2010 | Computers & Internet
How to enter WEP passkey for router when there are 4. using HP210
On your router set up interface you will find the wireless network key.
If it is WEP then it will show you WEP Passphrase and WEP Key.
You need to type in WEP key and not the passphrase. WEP key is 10 or 26 digit Hexadecimal number. You need to enter this 10 or 26 digit number.
open the set up page of the router and check the wireless settings of the router.
Click here for more information about the router and networking
Apr 19, 2010 | HP 2101nw Wireless G Print Server...
Securing my wifi network
Hi George,
Simply open your Internet browser, in the address line, inset 192.168.0.1, then:
-> Goto TOOLS
Here you set the administrator password, note that you have to set the same password twice.
Do set some security as well, other vice your neighbor will use your network, - and that you don’t want, as you don’t know what and where he go on the internet.
On page 27 in your manual, you find the way to set the wireless settings.
On page 37 in your manual, you find a way to set MAC address settings. Thise settings allow only those MAC addresses as you put in the table.
You find your own MAC address like this:
->Start->run->write cmd and hit enter; a black DOS window open, write ipconfig /all (note the space before /all). Here you find your MAC address – note that there is two cards in your laptop, and the card you want the MAC address for is the wireless card.
regards
Teis
plz let me know if you need furter help.
Jan 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
I want lock the belkin router for our house only
Ask your Internet service provider for the network IP. Go on the internet browser on the computer that has the router attached and enter that number. enter the user and pass for the router (normally the user is admin and the password is password). Open up the wireless tab and enter your wep key into the space and now the router needs a wep key to access the network.
Hope this helps,
RCF
Aug 30, 2008 | Computers & Internet
Computers & Internet Logo
1,307 people viewed this question
David Payne
David Payne
