Question about Fargo HDP5000 Thermal Printer
Printer ribbon stuck hdp 5000 - Fargo HDP5000 Thermal Printer
My cannon printer mp510 gives me an error code 5000
No problem that's why I asked I couldn't find a 5000 error for this machine. Open the cover and wait for the print head to come to the center, then pull the power cord from the back of the printer. Once the power is off you can now move the carriage to the far left so it is out of the way. Now use a paper towel and gently blot all the excess ink off of the ink Pads inside the machine on the far right and press them down. If the Wiper blade is extended, clean it and it should snap back in position. If it is still stuck, try sparying the area with Windex but don't get any on anything except the pads.
Mar 04, 2015 | Cannon Office Equipment & Supplies
Fargo HDP 5000 heater error 161 fault
This error usual occurs after a large print job (50 prints in a row). Try shutting off the printer, and leaving it off for a good 15 minutes. Turn back on and retry.
If the problem persists, then you should contact a service center. It seems to have a failure in an internal sensor.
May 06, 2014 | Fargo HDP5000 Thermal Printer
Image color adjustment hdp 5000
on the printer property dialog select image color tab then advanced settings, for darker images increase sharpness and contrast and decrease gamma to you satisfaction
Aug 26, 2013 | Fargo HDP5000 Thermal Printer
Error 103 headlift error fargo hdp 5000
erro 103 could cos by head voltage erro or head fit erro.
this could be a problem with the printhead lift or transfer roller headfit.
reset the printer and try again ...
Jan 05, 2013 | Fargo HDP5000 Thermal Printer
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
We just bought Fargo HDP5000. on first installation now its bringing error code 97 and 99 which when we calibrated the printer the error 99 was solved. but the error 97 is still there. pls help
hola hermano tengo problema con mi impresora hdp 5000 cada vez que boy a imprimil me da un error 103 y 105 me dice en la pantalla del monitor de mi pc que el sensor no detecta el movimiento del cabezal
Apr 19, 2011 | Fargo HDP5000 Thermal Printer
I have an alps 5000 that won't pick up the ribbon cartridges?
It could be a serious error with the cartridge changer. Take a close look at the chagner for anything that looks bent or mis-aligned. Also, may sure all of the positioning sensors are clean.
Mar 26, 2010 | Alps MD 5000 Thermal Printer
How do I print using the foil ribbons? I do not see Gold foil as a color choice.I am interested in any info from a manual on this subject of gold or silver foil ribbon printing.
Your ALPS MD-5000 MUST be set to print in DYE-SUB. mode.... Is there a Memory upgrade plugged into the slot next to the Printer Port? If not, then it's not an option......
Feb 11, 2010 | Alps MD 5000 Thermal Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Alps MD 5000 Ink Ribbons Breaking!!!!
try the settings for thick paper .(for anything more than 80grammes)
Sep 18, 2007 | Alps MD 5000 Thermal Printer
Fargo HDP5000 Thermal Printer Logo
62 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
