Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Oil leaking under liefter cover - Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
07 saturn outlook 3.6l fwd. leaking oil from under the intake manifold
Did you ever find the source of the oil leak from under the intake?
Nov 15, 2013 | 2000 Saturn SL
Oil leaked out from the oil cap and the engine cover has a missing screw
Oil may have been over filled , if not a faulty cap , the missing screw wouldnt cause a leak from the cap , check no oil leakage around missing screw (may need to clean area first) this could cause rocker cover gasket not being compressed properly
Feb 10, 2013 | Holden Barina Cars & Trucks
Engine oil leaks
severe oil leaks would be front timing cover crankshaft seal and the rear main seal or leak at oil pump at front timing cover oil leaks can come from damaged oil filter seal or damaged oil pressure sending unit.slow oil leaks oil pan gasket the valve cover gasket leaks you will see and smell smoke from under engine compartment which could be a fire hazard.
Oct 07, 2012 | 2001 Cadillac DeVille
Why is oil in sparkplug wells?
there are o-rings that are under the valve cover that seal the valve cover to the cylinder head, they are leaking and allowing oil to leak from under the valve cover into the spark plug wells, all you need to do is replace the valve cover gaskets and wa-la the oil problem will be fixed.....good luck
Apr 16, 2011 | 1998 Kia Sportage
The oil leaks out under the car
OIL LEAKS UNDER CAR COULD BE COMING FROM LEAKING OIL FILTER OR OIL PAN GASKET.CHECK FOR OIL LEAKS AROUND REAR MAIN OIL SEAL AND FRONT TIMING COVER CRANKSHAFT SEAL LEAKING OR LIP SEAL AT THE LOWER TIMING COVER TO OIL PAN.
Aug 03, 2010 | 1988 Ford Taurus
Coolant leak front under oil fill cover s engine
OK, 4.3 V6 ? Coolant leak is coming from under the oil fill cover ? , do you mean the oil fill tube ? Could be a bypass hose is leaking, or a manifold gasket is bad, need more info maybe, pics
Feb 01, 2010 | 2004 Chevrolet TrailBlazer
Leaking oil
rear main seals dont just stop leaking it sounds like its your valve cover gaskets leaking and running down
Mar 04, 2009 | 1994 Cadillac Fleetwood
Oil leak on right side under top engine cover
your valve cover gasket may have blown. This can happen if you overfill above the required dipstick level. take off the valve cover and check the gasket. Better to be under the level than over. The oil preassure will try to blow from where ever there is a weak gasket.
Nov 28, 2008 | 2004 Kia Sedona
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
14 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
