Question about Minolta bizhub 350 Black and White Copier
I need to change the pc drum
Does anyone know how to do this?
  • 1,800 Answers
The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Posted on Jun 18, 2009
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Drums and guitar swapped over on ps3 guitar hero
just use the guitar as drums & use the drums as a guitar... nah just jokes you won't be able to fix that unless you get some pro guy to repair but it'll cost you around the same price you brought it. goodluck though...
Jun 06, 2010 | Activision Guitar Hero
Cannot dis-mount the drum to change break pad
Drums Probably Have Deep Groove Cut In Them--BACK OFF AJUSTERS--This Will Allow Removal.
Dec 19, 2009 | 1996 Dodge Caravan
I have a EX-3535 fuser error code 004-361 coming up on a new fuser on a machine. I changed the fuser for another new one and still get it so suspect I need to do an NVM setting but don't know which? Can...
4-361 Drum Motor
Drum Motor failure.
Initial Actions
• Remove all Drum Cartridges.
• Perform REP 1.6.
Procedure
The machine is a DC3535.
Y N
Enter dC330 [004-003] and press Start. The Drum Motor energizes and the drives
rotate.
Y N
Go to Figure 1 of this procedure and measure voltage between the Drum Motor P/
J210-4 (+) and GND (-). +5 VDC is measured.
Y N
Go to Figure 3 of the +5 VDC Wirenets and troubleshoot the problem.
Replace Drum Motor (PL 1.1).
Dec 01, 2009 | Xerox DocuColor 3535 Copier
Oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Jun 19, 2009 | OKI B4600 Printer
Money (change) caught inside interior drum plastic pieces.
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
May 10, 2009 | Kenmore 63942 Dryer
Hello, Our Minolta Dialta Colour Copier/Printer CF 2002 has come up with a "C-0208" malfunction right after the maintenance contract expired... Can anyone help, please?
C0208: PC Drum Charge Corona malfunction. The SCD signal is detected for a continuous 0.7-sec. period while the PC Drum Charge Corona is being energized.
Relevant Electrical Parts - Image Units C/M/Y/Bk, High Voltage Unit (PC Drum CH.) HV1 IO Board (PWB-IO)
Steps (in this order) - Check the Image unit contacts and correct
or clean as necessary.
Check the HV1 contacts and
correct or clean as necessary
Change Image Unit.
Change HV1.
Change PWB-IO
Aug 13, 2008 | Minolta Office Equipment & Supplies
ERROR CODE E000020-01b0
your yellow drum unit is bad replace it if the error ship to 000020-02b0 replace all your drum unit because all the units could be bad but the machine will show one at a time as you replace the drum units
Jun 13, 2008 | Canon imageRUNNER C3220 Color Copier
Changing the drum on a Gestetner dsm735 copier.
Hi , when you get a new drum unit you should be fine , the cleaning blade drum and everything you will need would be in there already , you can just slide in the new one
Jun 03, 2008 | Gestetner DSm645 Digital Imaging System
Minolta bizhub 350 Black and White Copier Logo
327 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
