Question about iLive Bluetooth Speaker System
Lost pin i have switch phones and have lost the pin to pair my phone to the speaker
I can't pair my phone with a bluetooth speaker.
Switch speaker OFF. Power phone down count to 10 and power back up. Go to Phone, Settings - Bluetooth - Search for Devices. Turn Bluetooth speakers on. When found by the phone, click PAIR. If asked for a PIN Code, the default is 0000 (four x zeros).
Any problems COMMENT below my name with make and model of phone and make and model of speaker.
Jul 05, 2016 | Cell Phones
How to pair I-phone 5c with Ativa b3d-b Mobil it speaker?
http://www.ehow.com/how_6151860_ativa-bluetooth-instructions.html This helped hopefully this will help you.
May 03, 2015 | Cell Phones
Need to know how to pair lost pairing info
first you have to turn the power to blue tooth on ,then you will have to put ur speaker into discovery mode,most blue tooth manufactures use the power button for this feature by holding it down for 6 to 10 seconds when turning on the device it will put it into discovery mode,your phone or computer or game system should be able to recognize the blue tooth device then.It will ask you for a pin pairing code,now most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999 hope this helps
Feb 26, 2011 | Blueant Sonic Bluetooth Portable Speakers...
Pin code for Altec Lansing iMT521 SoundBlade BT Speaker to pair wit iphone 3gs
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 18, 2010 | Altec Lansing T515 Portable Speaker for...
I have a new phone (HTC EVO) and have lost my manual and can't figure out how to pair it to my BlueAnt Model BTSLBC3
Hey,
All you need to do is put the device into pair mode. To do this hold the green button on the ST Light, while holding the green button release the microphone arm. You should get a blue/red flash letting you know the device is in pair mode. When you get this, go to your phones bluetooth menu and search for devices. Select the ST Light and if prompted enter the pin 0000.
Regards,
Dec 08, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Need code for g2 earpeice
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | BlueTrek G2 Consumer Headset
I have lost instructions from my Jabra BT250 and can't remember how to pair? my new phone is a htc
switch off jabra. Hold down on/off button for sabout 10 secs until blue light is continuously on. Then pair from the phone. Pin 0000
Jul 05, 2009 | Jabra BT250 Consumer Headset
Pin code for a HBH-608
Lost the manual and now I can't re-connect with it,,phone sees it but can't be paired cause no pin cod
Dec 30, 2007 | Cell Phones
iLive Bluetooth Speaker System Logo
76 people viewed this question
Top iLive Audio Players & Recorders Experts
cwradio73
Andrew Taylor
Andrew Taylor
Are you an iLive Audio Player and Recorder Expert? Answer questions, earn points and help others
