Question about BAK 2003 Dodge Dakota - Quad Cab, 5 3" short bed - ProCap Bed Caps
2003 dodge dakota quad cab makes popping sound when gas is applied
When gas is applied makes popping noise.does not do it all the time. started doing it after I had jets cleaned.
Replaced front driver side axle on my 4wd. Now, when 4wd engauged it makes slight nois when i torq on it. Did i miss something?
Here's a video on the same model/make with something that started as a noise. Turns out there are two different axles with the difference being the locking ring on the inboard end. Dodge Dakota Front Axle Noise
Oct 06, 2016 | 2000 Dodge Dakota Quad Cab
Truck will not stay running unless I keep applying gas and it warms up
Is the check engine light on ?
Sounds like the idle speed control is faulty.
Feb 19, 2015 | 2000 Dodge Dakota Quad Cab
I have a 2003 dodge dakota quad cab 4.7l v-8 4x4 with p0440pd and p0442pd for engine codes that are on can't find out what they are.
P0440-GENERAL EVAP SYSTEM FAILURE, Check your vacuum hoes by the cannister close to your fuel tank.
P0442: Evap leak monitor, Small Leak Detected, check/change your gas cap should fix that problem!
I hope this helps!
Mar 05, 2011 | 2003 Dodge Dakota Club Cab
I was driving my 2000 dodge dakota quad cab, and all the sudden it bucks acts like it wants to die ,maybe out of gas . The fuel gage says 1/2 a tank. I go in the store and come out try to start it , it act...
Hi
"Keep a spare gas cap" sounds to me like the fuel pump is failing or some fool has fitted it the wrong way, the pressure will build up in the tank and pop the cap off. I would look at the fuel relay and check all the wireing to the fuel pump as this sounds like someone has been tampering with the fuel system, most commonly why is because the fuel pump can cost around $500 to $1000.
Is this a gas version or a diesel version, plaese calify.
Regards
Dan
Dec 28, 2010 | 2000 Dodge Dakota Quad Cab
Have 2000 dodge dakota quad cab air conditioner quits
When you recharged the vehicle did you have it vacuumed?
Apr 09, 2010 | 2000 Dodge Dakota Quad Cab
Surge when creeping in traffic
I have seen these trucks do this from a defective TPS.
Dec 05, 2008 | 2003 Dodge Dakota Club Cab
BAK 2003 Dodge Dakota - Quad Cab, 5 3" short bed - ProCap Bed Caps Logo
21 people viewed this question
Top BAK Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a BAK Air Tool and Compressor Expert? Answer questions, earn points and help others
