Question about Compaq Computers & Internet
Compaq dx 1000 processor fan does not pick power.what might be the problem?
    Sergeant:
  • 252 Answers
There might be issue with the power cable of the Fan or socket on which power cable fixed is not working.
Try to connect the Chassis Fan on this socket. If works then issue with your Fan or not then issue with your socket on motherboard
Posted on Aug 20, 2014
Is there a quick fix to replacing the processor fan on a Dell Inspron 1000
Not a quick fix, but you can buy a cooling base unit for it which plugs into one of your usb ports which supplies power for the built in fan.
Aug 20, 2014 | Dell Inspiron 1000 Notebook
Compaq presario a928ca laptop has overheating problem laptop overheats within a minute & we cant put it on table also we need to put some support below so that air can pass below it.
The first thing I would do is open the case and remove the fan and heat sink for the processor. You will probably find a little "radiator" looking device clogged with dust bunnies. Clean it out good with canned air and reinstall it. Be sure to clean the processor and heat sink then reapply heat sink compound. Clean all your fans and, with the case open, power up and look at all your fans. Are they all spinning at full power. If not, replace them. Reassemble the case. You should be good.
Mar 20, 2014 | Compaq Presario A928ca Laptop Lcd Screen...
Compaq presario sr5000 no power but fans run cd rom opens and closes.
First check the processor fan is working if working remove the memory from the slot clean with a clean cloth and rub the conector with a erasor dont use any metel or any other thing insert the memory and see if the lock is locked on to memory properly still not working change the memory sutable for the memory slot still not working removce the processor heatsink and the processor clean the surface and apply athin layer of heat sink compound and fix back the processor if still not working change the processor if still not working use an addon graphics card and check for display
Oct 27, 2011 | Compaq Presario 5000 PC Desktop
On startup my fan on my dx2200 run very loudly
Which of the fan? Is it Power fan or processor cooling fan?
POWER FAN: check if the casing of the power pack is touching the fan or wire if not then prepare to change power pack or the fan.
Processor Cooling Fan: If there is no wire in the system touching the fan then know that the ball bearings are getting bad. Then plan for replacement.
Oct 13, 2010 | HP Compaq dx2200 PC Desktop
My compaq laptop F500 has black screen when power on
That sounds like a power supply problem. That would be the first thing I would check. If it was the processor, you would have heard a long beeping sound or if it was the memory you would hear about three 'annoying beeps'. The main reason you indicated there is no display on the screen and that the fan spins for a few seconds then shuts off, would hint that power is not going to the mother board long enough to spin the processor or cooling fan. Hope this helps :)
Apr 17, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq evo desktop machine processor fan problem
your fan may have quit working if that is the case you need to replace it ASAP befor your processor over heats and fails if that happens no mre processor
Apr 02, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Processor fan wont work.
Hi tenfive64,
Try another fan in the cpu power slot, to see if there is no power getting to that source. If the fan turns on, well! Something ain't right with the fan. If it doen't then you'll need a power extension connector to reach for another fan power source on the board. DON'T hook it up to a non-fan power source, you will fry the fan, if not the board.
Good Luck,
Mark
Dec 16, 2009 | Compaq Computers & Internet
I recently had a new power supply installed in my compaq presario SR1318NX, now the fans run almost constantly. The air from the fans does not feel hot, nor does the tower. Is this serious?
In a desktop computer the fan is supposed to run constantly otherwise the processor would get that hot the system would repeatedly shut down or even damage the processor or motherboard.
If the fan is noisy then chances are that the fan blades need cleaning of dust.
Other than that you have nothing to worry about.
Regards.
Dec 02, 2009 | Compaq Presario 5000 PC Desktop
Cpu fan can not detect when boot at hp dx 2300
check the fan and be sure it is plugged into the motherboard
Aug 14, 2009 | HP Compaq dx2400 PC Desktop
Computer won't boot up
Check the heat sink connected on your processor and its cooling fan is working or not
Apr 09, 2009 | HP COMPAQ Presario SR5410F Pentium...
Computers & Internet Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
