Question about Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA
Zone shutoff My sprinkler timer works, it turns on the water at gold pin. However, last two days I have walked out at 9 am and last zone is running. The pump is not on any "gold pins" and only shuts off manually. Why is it continuing to run after passing the gold pin? I thought pump should not run where there is not a gold tripper. Yet this one keeps running. This is something new that just started. I was thinking the index valve was messed up. But then remembered the pump should be turning off after it passes a gold pin? Whta should I look at to fix this other than remove the whole system and replace with a digital system??? Frustrated with Intermatic timer
2 Suggested Answers
SOURCE: I have Intermatic sprinkler model
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Posted on Apr 28, 2011
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Melnor water timer
Melnor is major water timer company, and not off-brand. However, water timers last a couple years, or less, sometimes they last long time but that is not often.
If not drained completely of water, they will break when water freezes.
Copy following link to identify all water timers on market today:
Most timers have 1 year limited warranty for defects in workmanship.
Jun 05, 2013 | Hardware & Accessories
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
Jul 27, 2011 | Intermatic R8806P101C -...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Apr 27, 2011 | Intermatic R8806P101C -...
I have misplaced my manual for the 24-hour timer, and I want to make sure I am using the "tripper" clips appropriately: do I place one in each slot that I want the sprinkler zone to run--and...
This device is simply a 24 hour timer. It has a special enclosure classified as "Rain Tight" that helps prevent rain from entering - as water from a hose directed at it would enter the enclosure causing damage to the timer.
It is NOT a timer designed to operate a traditional pop-up sprinkler system. Those timing devices allow water to flow into the lawn sprinkler system and spray out from a certain area of sprinklers for a predetermined amount of time, then switches this area or zone off and turns on the next. This continues until all zones have watered the area where sprinklers have been installed.
The device you are asking about simply switches power on and off to one load. It can not control multiple loads - or as in your case "zones". You would install ON trippers at the time of day on the yellow time disc when the load would be ON and install OFF tripper when the load should be turned OFF. If the load were a light, you could turn this light on and off many times a day - dependent only on how many ON and OFF trippers you installed on the yellow time disc.
A sprinkler timer must be selected instead. This will allow you to select the number of days between watering, will operate many zones, control of how long the water is to remain on to each zone, detect if it has recently rained or if it is currently raining, etc. One is pictured below:
I hope this helps. If you have additional questions or comments, please provide the manufacturer's name AND the exact model number of the timer you are talking about. Good luck. Please rate my reply. Thank you.
Apr 13, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
RE: Intermatic model T8845PV used for a sprinkler system. The system works fine on manuel but does not come on on the days selected when on automatic. Day pin is pulled out and aligned with 12 0r 14...
1) Check that yellow timer dial is rotating and keeping correct time > if not, then buy new clock motor
2) Check that silver tripper pin is installed at 12 midnight. This tripper advances day-skipper wheel each day at midnight. Check that tripper is advancing the skipper wheel.
3) Rotate skipper counter-clockwise until current day lines up with 14 arrow.
4) Check gold tripper pins are pushed in place.
Open following links for parts list
http://waterheatertimer.org/pdf/Setting-Intermatic-sprinkler-timer.pdf
Apr 03, 2011 | Intermatic Hardware & Accessories
How do you set the days that you want the system to operate ?
R88 series timers at Intermatic.
Click on model number to see manual:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Add a comment if you have different timer
At fixya, we're not supposed to copy-paste from manual, but manual says information clearly.
If timer has the day-skipper wheel located lower left of large yellow dial:
Not every timer has day-skipper wheel, in which case timer works same for each day.
TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
until today's day is in front of "14" arrow. Press pins DOWN on days
of NO watering. The skipper wheel must have all pins UP for daily
watering.
Additional instructions:
1. TO SET FIRST ZONE: For watering, push gold pin into slot on yellow
dial at desired ON time. For each 12 minutes of additional watering
add one pin WITHOUT skipping a slot.
2. TO CHANGE ZONES: Leave one blank slot on yellow dial after ON
line (gold pin), and valve will automatically advance to next zone.
3. TO SET ADDITIONAL ZONES: Repeat steps 1 and 2. REMEMBER
to leave blank space between zones
4. TO SET TIME OF DAY: Turn yellow dial CLOCKWISE, until correct
line is at end of silver time pointer. Do NOT turn silver pointer.
5. TO SKIP DAYS: Turn black skipper wheel COUNTER-CLOCKWISE
watering.
6. PUT SELECTOR SWITCH IN AUTO: This switch can be used to turn
the system ON or OFF for manual operation without affecting the set
program.
Nov 24, 2010 | Intermatic R8816P101C -...
How do I install a T8845pv sprinkler timer. What do I attach to the two yellow wires
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashx
The timer is used to power a low-voltage sprinkler solenoid valve.
A solenoid is an electrical switch that opens and closes a gas line or water line.
The yellow wires go to your sprinkler system solenoid valve.
The solenoid is the valve that turns water on-and-off.
The 120Volt electric cable that runs the timer connects to the Line and Neutral terminals.
Black to Line terminal, white to neutral terminal
The clock repeats each 24 hours.
Lift and rotate dial until current time lines up with silver pointer
The skipper wheel has pins >> press pin down for each day you do not want watering
Rotate skipper wheel counterclockwise until current day lines up with 14 arrow
Put tripper pins on yellow dial
Each pin represents 12 minutes of watering
To water for 48 minutes, put in 4 consecutive pins
Put pins on wheel at the time you want watering to take place.
To water twice a day, put pins at two different times, and do not put any pins between those times.
Oct 28, 2010 | Intermatic T8845PV - Sprinkler-Irrigation...
HOW DO I SET TODAY MONDAY, SO THE PUMP WILL START ON WEDNESDAY? I PUT MONDAY IN FRONT OF 14 ARROW AND PULL THE PIN OUT FOR WEDNESDAY BUT AS ALL PINS PASS ON YELLOW DIAL TO GET TO WEDNESDAY AND THE 12 MIN....
http://waterheatertimer.org/images/R8806P101C-timer-778.jpg
1) The silver pin goes at 12 midnight on large yellow dial. This pin advances the skipper wheel each day.
2) Turn yellow dial clockwise until current time lines up with silver pointer.
3) Rotate skipper wheel counter-clockwise until today's day (Monday) is in front of 14 arrow.
4) To skip a day of watering, the skipper pin is pushed down for that day. So you want to push down Monday and Tuesday.
For watering, the skipper pins is up for that day. So you want The skipper pin up for Tuesday.
5) The brass trippers are inserted on yellow wheel. Each brass tripper represents 12 minutes of watering for example. So if you want to water for 1/2 hour, then put two consecutive pins on the yellow timer wheel. For 1 hour, put 4 consecutive pins.
May 17, 2010 | Intermatic R8806P101C -...
Intermatic R8806P101C - Sprinkler-Irrigation Timer - 14-Day Skipper - NEMA Logo
46 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
