Question about Dehumidifiers
I have Model TWD-510BE. It has been working great until this week when the automatic on/off switch failed. Intermittently,the dehumidifier will not shut off even when I turn the dial to "off". The number on the switch is TW2001R-A. Also listed on the switch is TECXWELL. Can you advise me where and how I can obtain a new swith? I live in Northeast Pennsylvania. Thank you. Dianna Smith
  • 1 more comment
  • diannammsmit Jun 18, 2009
    The picture shown on the link you referred me to does not look like my switch.
    The number shown also is not the same as mine. The number shown on my old switch is
    TW2001R-A
    The automatic on/off switch on my Surround Air Dehumidifier has stopped working even when I turn the knob to "off". The serial number is 48000143 and the specification number is TWD510BE. The dehumidifier is approximately four years old.
    I am not having any success finding what I need. Apparently, the part I need is no longer available.
    I am aborting my search, but thank you for trying.
  • 334 Answers
Hey there if you go to the following link and put your zip code in the field, they should direct you to a dealer close to you.
Posted on Jun 18, 2009
  • Dehumidifiers Master
  • 13,433 Answers
  • Ekse Jun 18, 2009
    Then it must be the wrong part, I don't have any other parts. Try another expert, you have a link or a button below for getting another expert or reposting.
    That Is the only part I found with the part number.
When I press the power on button, why does it just beep and won't turn on?
There is an interlock that shuts down the dehumidifier when the bucket is not in place or not seated correctly. There also may be a "bucket full" sensor that shuts it down mistakenly. Another possibility is that the compressor has failed.
Dec 18, 2015 | Dehumidifiers
Haire model HD308 dehumidifier quit shutting off automatically when full?
usually the float is stuck. remove the resevoir and check the upper inside of the machine for the float. if you can flop it up and down easily, it's the switch attached to it that needs to be replaced.
May 10, 2012 | Haier HD308 Dehumidifier
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
I have a Windchaser dehumidifier Model WDH928. The problem is that it does not automatically shut off when the tank is full. The water just flows over the tank and out. I've had this for years and it...
The float valve sensor in the bucket is either stuck in the down position or has broken entirely. Accessing the interior of the tank is the only way to know. I would recommend that you use a continual drain hose, but that is not recommended, as the coils need some water in the tank to cool.
The real downside is, that Windchaser has been out of business (phones disconnected, website down, etc) for several months and parts are extremely had to find.
I hope I was of some help to you. Thanks for choosing FixYa.
Aug 15, 2011 | Windchaser MDH-W Dehumidifier
Dehumidifier runs but collects no water - coils are clean there is no obstruction the humidifier worked until a few weeks ago
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jun 17, 2010 | Goldstar DH504EL Dehumidifier
My Haier dehumidifier Model #39R171E is operating intermittently. The bucket is not full - power is on - temp in room says 59- do I increase the humidity to get it to work? Have a large amount of water in...
If your carpet is wet ... like mine was ... the best thing to do is bite the bullet and get the carpet out of your basement or where ever it is ... so your dehumidifier has a chance.
You reduce the % on the machine to reduce the humidity in your room. You should probably also get some fans going.
I have removed my carpet and padding and everything that I can reasonably remove from the room. I have 4 fans going and 2 dehumidifiers and two sump pumps. I also keep the windows open in the day time because it is more dry outside than in the basement. I have heat in the basement which I run at night. My goal is to save my house from damage due to moisture. It will be a good month for the electric company, that is for sure.
I'm sorry you are in this perdiciment ... I'm sorry for me too. My carpet was less than a year old and we have not had any water in the basement for 30 years.
Mar 03, 2010 | Haier HDN655E Dehumidifier
Our Surround Air Automatic Dehumidifier, Model TWD-21B, Serial 21B03260311 does not pull humidity out of the air anymore. The fan runs and cycles normally, but no water ends up in the reservoir. Any ideas?...
yes, the unit uses refrigerant, depending on the type unit maybe cost prohib to repair. You would need to check and make sure compressor is running. If there are no service ports then you would need to install service ports. we use piercing valves and then manifold gauges
Aug 09, 2009 | Dehumidifiers
No power
Factory Default Setting:
When the unit is first connected to a power supply, the
electronic circuit board will automatically default to the
following factory settings;
Mode: Dehumidifier
Humidity Set Air Value:60% RH
Fan Speed: = Low
NOTE: In the event of a power failure or the unit is
switched ‘Off’, the most recent settings are retained and
restored once the power is switched “On”/resumed.
IMPORTANT NOTE: Depending on the ambient humidity
conditions, when power is restored or switched ‘On’ the
dehumidifier may not start automatically under the factory
or custom (see page 7) default setting. This is an indication
that the ambient RH% level of the surrounding environment
is lower than the current default setting and it
may be necessary to select a lower set RH% value.
Feb 16, 2009 | Danby DDR586R Dehumidifier
Dehumidifiers Logo
497 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
