Question about La Crosse Technology WS-2811 WS-2811BROWN-IT Wireless Weather Station with Solar Powered Wind Sensor and PC Sotftware
Transmitter not working
New batteries and still not receiving information from outside transmitter
New la crosse technology wind speed weather station model # CA87092 set up.wind speed and outdoor temperature showed until this morning.new batteries used yesterday in setup. what is the problem?
The instructions for your station call for a specific set up procedure. Batteries should be installed in the transmitter first with time allowed for it to initialize and begin sending data. After installing batteries in the receiver, you should see wind speed and temperature displayed. BUT, here in the real world I have a Lacrosse receiver currently displaying a balmy 67 degrees inside and a not-so-balmy - - outside. I believe the alkaline batteries used in the transmitter lose efficiency or freeze at low temperatures. Warmer weather restores the outside temperature display.
Jan 05, 2017 | La Crosse Measuring Tools & Sensors
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Outdoor Temperature Transmitter not working
Sometimes, you have to remove all the batteries in the transmitter and receiver and wait a few minutes before the next step.
Then you replace transmitter batteries first and within 30 seconds, get the batteries installed in the receiver. This allows the receiver to link up with your transmitter. Both units need to be reset this way. You'll see the temperature and any other information the transmitter provides come up in a few minutes. This works with my La Crosse weather station. Using the reset buttons without removing power will not work. My nieghbour has a weather station from another manufacturer and this is also the only way that his will link up.
Oct 03, 2016 | Radio Communications
Can reset everything on my SkyScan Atomic Clock except for the outside temp. Have new batteries in both units. Main clock and outside remote thermostate..Any suggestions??
I expect that since the unit reads the outside temperature from the remote thermostat, there is no need to "reset" the displayed number since this data is obtained live from the thermostat.
Nov 04, 2015 | Home
My Ford Focus car doesn't centrally lock anymore, I have to use the key. It's not the fob battery because I changed it.
Sure you did put in a new battery? sure you did insert it correct? not the other way around? sure you did use the correct battery? like CR23 or AAA?
Sure all contacts in the battery compartment and on the battery are clean and shiny?
just a few things you could check.
Feb 09, 2015 | Ford Focus Cars & Trucks
I have eight atomic clocks,none of them have the outside temperature working,all have new batteries???
If your outside temperature is not showing on your clock, that may mean that the clock and the transmitter have lost their connection. To reconnect them you must first take the batteries out of both of the units for 15 minutes. First put the batteries back into the transmitter, and then the clock. Let them sit side by side inside your home. When both the indoor and outdoor temperatures show on your clock with the same reading, or within two degrees of each other, then you may put your transmitter back outside. Remember to keep the transmitter out of the direct sun in a dry place. Also keep it away from metal, which can affect the readings.
Oct 20, 2014 | SkyScan 86742 Digital Atomic Wall Clock
Remote control transmitter is good ,the receiver not working what can i do ?
Did you recently change the transmitter/ bought a new one, changed the battery? How did the problem start? Was it sudden or did the receiver die over a period of time?
Is is possible that the receiver is not recognizing the transmitter's signal. Do you have a spare transmitter? Is the spare transmitter also not working? Please give more information.
Oct 09, 2014 | 1995 Chevrolet Caprice Classic
How are the batteries replaced, in the transmitter first, then the clock?
The transmitter for your radio controlled clock is the atomic clock in your region, I wouldn't advise trying to replace the batteries in it.
I am guessing you are talking about a remote wireless sensor supplied with your clock! Put good quality batteries in this and place it next to your receiver (your clock) while it registers and then you can place it outside or wherever you want it.
Jun 04, 2014 | SkyScan 86709 Atomic Wall Clock
We just got a new Weather Channel wireless temperature sensor 9245. It seems that the transmitter isn't working. We followed the directions and put new batteries in the transmitter first, then the...
The new batteries could be defective or installed incorrectly. Remove all batteries and start over again. Be sure to let the transmitter initialize and begin sending data before you install the batteries in the receiver. If you can't receive a signal, the transmitter may have failed.
I have an Oregon Scientific receiver that is within line of sight of the transmitter and receives nothing......
May 17, 2017 | La Crosse Technology WS9245UBKITCBP...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
La Crosse Technology WS-2811 WS-2811BROWN-IT Wireless Weather Station with Solar Powered Wind Sensor and PC Sotftware Logo
24 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
