Question about Electric Mobility Merits Electric Wheelchair Scooter Battery Charger
Scooter wont drive both wheels - Electric Mobility Merits Electric Wheelchair Scooter Battery Charger
What do the beeps mean?
  1. Popular Drive Medical Ventura 4 Wheel Deluxe Scooter ...
    www.fixya.com > Forum > Mobility Scooters > Drive Medical
    Popular Drive Medical Ventura 4 Wheel Deluxe Scooter ventura418cs Power Mobili ...My Go Go Elite Traveller mobilty soccer beeps when I try to go Forward.
Jul 20, 2015 | Drive Medical Ventura 4 Wheel Deluxe...
My Pride GOGO scooter is stuck in drive and wont go into freewheel?
The park brake has got stuck, the brake needs to come off and be stripped down and cleaned, this will sort it.
Jul 25, 2014 | Pride Mobility Products GoGo Elite...
My scooter wont charge
Check to make sure the scooter isn't in free wheel. Make sure the scooter's drive is fully engaged. My scooter gets wet and that wetness messes with that mechanism I have to lub it about every two months or so. There is a switch associated with the freewheel lever that disconnects power [hot side] from the motor when the lever is in the freewheel position. On my scooter this switch gets stuck open or the lever will be stiff and will allow the switch to close. WD40 helps.
May 17, 2012 | Health & Beauty
I have a Dr.k scooter and the charger say it's full but it wont go
My 94 year old mother has Dr. K. Drive scooter (f66) 0511232 4067
Battery Pack S/N: 0521323 Model: HP-1202B. Her Great Great Children have misplaced the key. As Mother is no longer able to stand, I need to order a key so we can go for walk. Where do I order a key?
Patt
May 29, 2011 | Drive Medical Mini Phantom Three Wheel...
My Lynx L4 4-Wheel scooter green light flashing but it said it is charge it wont go forward
the green flashing light indicates an error with the scooter. Count the number of flashes 4 flashes pause 4 flashes pause etc and your manual should give you the meaning of the flashes Check to make sure that you are not in freewheel move the lever at the back of the scooter up and down a few times and make sure you leave it in drive mode turn on the power and see if the light stops flashing and the scooter will operate correctly Hope this helps
Oct 03, 2010 | Activeforever Lynx L4 Portable Mobility 4...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Scooter wont work. Charger shows "Green"......its been sitting for months. Just found the charger. When throttle is rolled on it makes a high pithched tone but crank wont turn the wheel...
Hi. I have had a few cases where the machine has been sitting in a damp room and the brake has rusted to the body and wont release. A few light taps with a small screw driver has usually fixed this. You will need to put the machine into free-wheel before doing this.
Could also be a faulty brake unit, that has seized up.
Try pushing the machine in free-wheel mode to see if the motor and drive wiil move.
Normally if there is an electrical fault with the brake assembly, then the machine will have a fault code on the display. good luck. Neil.
May 10, 2010 | RTO 12v 70ah Leoch Battery For Scooter Or...
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Electric Mobility Merits Electric Wheelchair Scooter Battery Charger Logo
26 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
