How to solve scanning problem? it said scanner is turn off. so how?
I have kodak i2600 scanner, when i was scanned document its getting black lines on the document how to solve this problem please help me
Black lines on most any scanner will be caused by dirt in the scanning system, or by a damaged/defective scanner sensor. You can clean the window.
Jul 15, 2015 | Kodak i2600 - Document scanner - 8.5 in x...
Hp scanjet 2400 is not work properly,, when i scan any pic, its scan half pic and other black background. please help me to solve this problem....
hp scanjet 2400 is not work properly,, when i scan any pic, its scan half pic and other black background. please help me to solve this problem....
Sep 07, 2011 | HP ScanJet 2400 Flatbed Scanner
How to solve bizhub 211 code error c0650
bizhub 211 error code C0F32, To solve this code simply replace the developer of the machine.
Feb 17, 2010 | Konica Minolta bizhub C250 All-In-One...
Hanging problem
scan the exit code it will close your scanner and then scan the recall default code (4 times) then scan the ENTER code your problem will be solve
Eshwer
Dec 18, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
How to clean lamp
Make certain that the scanner is not only turned off, but unplugged. And disconnected from the computer.
Then gently lift the glass off - the glass on which youy place whatever you want to scan.
Once the glass is off, you can clean both sides of the glass, but remember which side was facing up.
Also, if the bulb inside is truly dirty, you can gently clean the bulb.
Replace the glass cover, and reverse your procedure.
Plug it in, turn it on, connect it up again, and try it. It should solve your problems.
-a.
Jul 02, 2009 | Canon CanoScan 9950F Flatbed Scanner
Scanning speed slowed...
did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
Jun 27, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Lost Disc 2 for setting up my acer scanner
code [ffff:0027] be occured when we are making scan page & others option, plz solve this problem
Mar 16, 2008 | BenQ S2W 5300U Color Scanner
Scanner error 6
in my network i have hp M1005 printer always i'm getting this msg "scanner error 6 turn off
then turn on"
when i make turn off and turn on again same msg comming
how can i solve this problem...
Jan 16, 2008 | HP LaserJet 3050 All-In-One Printer
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
12 people viewed this question
jasbo
jasbo
