Xerox 550 errore 093 329 - Office Equipment & Supplies
Vignette printing problmes on xerox 550
It's a bit since I last saw this problem.
I would need a lot more detail to get to the bottom of your problem.
if you have been able to print out the Vignettes before then you can eliminate software, firmware & print driver.
You might have a problem with the laser units, black/cyan or magenta/yellow, the window underneath could be dirty.
If all this is a bit too daunting then you got to get hold of Xerox.
Sorry,
Goodluck.
Oct 08, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox 550 manual
Hi Anonymous,
You need to get hold of your Xerox Concessionaire,
as for a 550 manual you'll be lucky even I don't have one of those.
Regards.
Jul 27, 2014 | Xerox Office Equipment & Supplies
How do I change the cartridge region from a xerox workcentre 3550
The toner cartridges have a small CRUM chip fixed on the end of each tube. If you change them from a previously empty cartridge then it will still show empty. You just can't fool them.
Good Luck.
Jul 14, 2014 | Xerox Corporation WorkCentre 3550 Laser...
My Photoshop sends a print job 100 times to my Xerox 7800 instead of once for 100 prints.
I also have this issue running a xerox docucolor 550 and PS-CS6 the only soloution i have is to save the file as a pdf and send it from firey comand center if you are running a firey server command center is available from xerox website
Sep 11, 2012 | Xerox Phaser 7800GX LED Printer - Color -...
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
14 people viewed this question
k24674
