Question about Ovens
I am a renter in an NYC apartment and my
I am a renter in an NYC apartment and my kitchenette has a Welbilt Electronic 4 burner range and oven which is 20''w X 28''d. I am not sure what year it is, but here is the problem: The gas is coming, and the spark is occurring, but the burners will not light. When I hold a match to the burner, the burner will light, but once turned off, it will not light again. I think this is an electronic ignition with pilot, but cannot be sure, and if it is, I want to know where I should be lighting the pilot, but I cannot figure it out. Please help!
  • glenn24827 Jun 18, 2009
    Thanks, but I think I was unclear about the problem.
    When lit at the burner, the burner works fine. The spark is fine...good spark. Just no ignition from the spark. So I know gas is getting to the burner, and I know the spark is good, I just can't figure out why no ignition.
  • 1,305 Answers
Try cleaning the area around the ignitor tips close to the burners. make sure there isn't buildup ..clean and dry. Check for ample spark.
also make sure the orofices in the burner are all clear.
If the burners are removeable, you can run them thru a dishwasher cycle (if available).
let me know if this clears it up.
K
Posted on Jun 18, 2009
F20 error code on Frigidare electric range
Hello rjshomesnj - Typically error code E20 indicates that the range has detected a communication failure between EOC (electronic oven control) and ESEC system (electronic service element control). In other words, the range has an issue with the switch for the burner. I will personally recommend contacting a certified technician to move forward accurately and to assist with the repairs. You can often locate qualified servicers by visiting the manufacturer website.
Mar 01, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
We have a frigidaire self cleaning oven . It made a bang and now there there is no power to my oven. Clock does not work , Burners on stove still work.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
Jan 21, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
    In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
    Sep 19, 2009 | Ovens
    Magic chef gas oven range 6498xvs oven no longer works.
    i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
    May 20, 2009 | Ovens
    Gas range won't work
    Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
    If I can help further, please let me know.
    Thanks
    Vic
    May 15, 2009 | Magic Chef 9122 Gas Single Oven
    Oven will not light
    If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
    Nov 20, 2008 | Frigidaire Ovens
    Spark module clicks and gas will not stay lit, flame comes on but goes out
    hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
    Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
    Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
    Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
    Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
    thank u.................
    Sep 11, 2008 | Ovens
    Ovens Logo
    127 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
