Question about Canon Office Equipment & Supplies
Cannot print RX data - Canon Office Equipment & Supplies
MF Digital Scribe 9000 with Picojet disc printer. Hello, could anyone please help with the pin configuration connections of the 9 pin seriel cable to mini din control cable connection from the duplicator...
Have you tried emailing tech support?
http://www.mfdigital.com/techsupport.html
Failing that, and lack of pinout, serial communications can be done with only 4 connections, Transmit and Receive (TX, RX) ground (GND) if you do it with no handshaking. You'll need Data Terminal Ready (DTR) and Data Set Ready (DSR) and or CTS/RTS (Clear/Ready to end). You may have to trial and error it.
Pin 1 - Carrier Detect (CD) - only needed for a modem
Pin 2 - Receive Data (RX) - Cross over with TX
Pin 3 - Transmit Data (TX) - Cross over with RX
Pin 4 - Data Terminal Ready - Cross over with DSR
Pin 5 - Signal Ground (GND) - Goes to other side ground.
Pin 6 - Data Set Ready (DSR) - Cross over with DTR
Pin 7 - Request To Send (RTS) - Cross over with CTS
Pin 8 - Clear To Send (CTS) - Cross over with RTS
Pin 9 - Ring Indicator - Only needed for modem
May 20, 2014 | Computers & Internet
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
I am still unable to receive faxes that are printed automatically when they arrive. they mst be going to memory and i cannot get them to print out of memory. can yo please help me. i paid for this service...
If you are getting a low ink message no you will not be able to fax until this is resolved. Once you replace the ink cart. then you can get to the steps where you can clear the fax memory until then the steps that we would give you will not work.
You can visit www.canon.com click on your printer model then on support and you can download the manual in this manual there will be step by step instructions on how to clear the memory on the fax. this can also be cleard once you print them keep that in mind. so first purchse ink then your going to print your faxes by hitting that button twice the reason why it will not work now is because your low on ink.
If you like this solution please hit accept.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Canon MX310 Office All-In-One Printer
3 light on last two blink
The first light, I assume is on constantly, is power/connection, and the two that blink will be Rx and Tx, Rx = recieving data sream, Tx = sending data stream, even if you think that nothing is being transmitted, "static" is sent/recieved to maintain your connection.
Jun 11, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
I want to have the MX310 to answer on 4 rings
Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [ RING COUNT] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Try to download the manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603#DownloadDetailAct
I hope it helps!!!
The TX Report and RX Report print upon transmission or reception offaxes depending upon the settings made in [FAX SETTINGS->TXSETTINGS->TX REPORT] and [FAX SETTINGS->RX SETTINGS->RXREPORT], respectively
Dec 08, 2008 | Canon PIXMA MX310 All-In-One Printer
Memory RX, Recording Printing JAm
yes you can! if you really want it! you may enter the menu and in printing menu look for rx and press enter, or look for print from memory! it should work
Nov 03, 2008 | Minolta MF1600E Plain Paper Laser Fax
Canon FaxPhone L80
Press Function, Data Registration, and then Set. Use the up/down arrows to select "report settings", then Set again. Using the arrows and Set change the values or TX REPORT and RX REPORT to "YES". This will pring a TX/RX report after every fax. When you are done press Stop/Clear. This is from Sectioon 14 of the owners manual. Let me know if you need more help.... Mediaman85@mchsi.com
Aug 20, 2007 | Canon FAXPHONE L80 Laser
27 people viewed this question
old marine
old marine
