My 96 honda passport tape deck won't accept tapes How do I fix this
  • Audio Player... Master
  • 1,258 Answers
Take it out and put it on the bench and service it. You will need a power speaker harness usually as well as speakers on the bench and a good 12 Vdc supply. That's how you fix those. I did it in my early days on all kinds of models and brands. The harness might be found at Crutchfield.
Posted on Jan 02, 2015
2 Suggested Answers
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Audio Players & Recorders
HP SureStor DAT24 won't exit clean mode, won't accept tapes
give it cleaning tape >>> once it finishs cleaning it will eject cleaning tape then you will be able to put any other taps
Apr 08, 2013 | HP Surestore DAT24 DAT Tape Drive
Radio won't eject tape
tape is probably caught in the reels, you might have to force it out of the deck, i forced mine out with my eyebrow tweezers, the tape was obviously ruined cause it ripped, but better the tape than the deck...
Aug 17, 2012 | 1997 Buick LeSabre
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Pioneer Stereo double cassette deck Ct-W302R - is it repairable?
They might be repairable but usually at a cost that exceeds it value. Who wants to pay $150 to fix what was known as a throw away tape deck? Not many. It might even exceed $150 as they are complicated to repair bot being designed to be repaired.
Mar 22, 2012 | Pioneer Audio Players & Recorders
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
Deck will not accept DV tape
most likely problem is a defective cassette housing. I've replaced about a dozen of these in AG-DV2500s.
Jan 12, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
37 people viewed this question
 Grubhead
Grubhead
