Question about Roper RAS8445KQ Top Load Washer
Roper RTW4640YQ1 noise at various stages
Sometimes when filling for rinse cycle it makes a loud grinding noise then will finish cycle other times it is just before it unlocks
  • 3 Answers
SOURCE: Roper Washing Machine works after I jolt it
See link: http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
Posted on Jul 27, 2007
the dr
  • 447 Answers
SOURCE: Grinding Sound
Sounds like the brakes have become noisy, just like in an automobile if they glaze over they start to squeak. This really wont hurt the machine but if you dissasemble the machine (or pay a professional at the most 1.5 hr labor since your washer is the best design and fairly simple to repair) and clean the brakes (basket drive assy) and the drum (part of the tub support)
Posted on Oct 15, 2007
freetek
  • 5568 Answers
SOURCE: my roper washer won't spin
You should probably remove the water by hand if it will not pump and then pull the unit out far enough to get behind it. Have a bucket handy to drop your water supply hoses into since they will drain.
Back panels are mostly held on by a handful of screws (no more than a dozen) and once removed, you can peer inside with a flashlight.
If you see leftovers from a shredded belt, cheer!  The transmission would be far more costly to replace.
The belt can be had many places but I suggest you go to Sears website, then the parts department with your machine model number handy. They have a huge collection of parts illustrations for thousands of machines and Roper (now a Whirlpool company) is a common name. You should be able to get the mfrs. part number there and then search further or buy it from Sears.
Posted on Dec 21, 2008
onthejob5130
  • 640 Answers
SOURCE: roper wash machine ras7133kq1
no theres something in your pump,,it up against the impeller in your pump.....onthejob
Posted on Jan 31, 2009
jsrock516
  • 5911 Answers
SOURCE: Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Posted on Oct 04, 2009
Roper top load RTW4640YQ1 will not drain. It makes a grinding noise but no drain. Lowered drain hose and water runs out draining tub. So, no pumping water out, but no blockage.?
could very possibly be a pin , coin , bra wire etc caught in the impeller blades preventing the pump from working
remove the pump and undo the housing of the impeller and check for obstruction
Sep 11, 2016 | Roper Washing Machines
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Roper washing machine makes grinding noise on spin cycle but the tub doesn't turn
It sounds like you have a motor coupling that is broken. There are videos on YouTube to show you how to repair this. Search for "motor coupling repair on direct drive".
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Jul 27, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
44 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
