Question about Estate ETW4400TQ Top Load Washer / Dryer
No Agitation The Washtub fills with water as normal, then there is a small "humming" sound like the cycle to agitate has begun, but the agitator does not move and the machine turns off
  • michaelasdad Jun 18, 2009
    Thank you kindly - that is what i was afraid of. Only 1 1/2 yrs old, doesn't get overused, single guy here so not a ton of laundry, maybe used twice a week
  • 520 Answers
Ether the belt is broken or the transmission has failed.
Posted on Jun 18, 2009
  • Chris  Jones
    Chris Jones Jun 18, 2009
    Try the belt first. You may get lucky.
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
General Electric Washing Machine want agitate. The washer fills, spins, drains but simply stops agitating or washing during different cycles. I have checked the lid switch, coupling under the agitator and...
The water level switch may be going bad. As the water level rises to the proper level, it switches a set of contacts inside to stop the water fill and cause the machine to start agitation. Make sure machine is empty before you replace the water level switch---it works off of air pressure from a small hose attached to it.
Feb 16, 2015 | General Electric Washing Machines
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Need info about extra rinse cycye
there should be agitation..dont know unless its not making the connection in the control head..
I have a Kenmore 90 series washer that overflows. What is happening is that during the initial fill, it shuts off. However, part way through the agitation cycle, it adds more water and would overflow...
In the old days before electronics took over a small bore tube connected the washtub to a pressure switch. As the water level rose a pressure would be created in the washtub and at a predetermined level the pressure switch would cut off the water supply. A blocked tube or a broken pressure switch (or a leaky washtub) would cause flooding. A leaky washtub would prevent the required pressure build up.
I haven't been inside a modern machine so I don't know the arrangement but I expect it is similar - apart from the switching, which will be performed by the computer, digitally of course...
Oct 23, 2017 | Washing Machines
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
Estate ETW4400TQ Top Load Washer / Dryer Logo
161 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
