Question about Meridian Lands Phones
M522 Meridian Mate Expansion Module program buttons
How do I re program my meridian phone to make out going calls
you probably forwarded the phone, check and see if there's a cancel button or a goodbye button (turns forwarding off on my phone)
Nov 12, 2014 | NorStar Meridian M7310 Phone
How to program feature buttons on meridian 7310?
Go to 7310 set you wish yo program leave handset on hook push feature star 3 then the button you wish to program then feature and
the code you want ex:feature 0 is speed dial that key will now be
programmed for speed dial. You cant program line keys or intercom keys.
Sep 02, 2014 | NorStar Meridian M7310 Phone
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
How to programe the 14 button on the m3820
When you connect a Nortel Meridian M3820 phone to a 3300 CITELlink Gateway andprogram it as a CITELlink Type2 device, ... Button Label. Function ... Feature Key 4. 11. Feature Key 5. 12. Feature Key 6. 13. Program. 14. Menu Right
May 07, 2011 | Nortel Meridian M3820 Corded Phone
How do I find out what my extension number is on my meridian phone
Press feature *0(button inquiry) then your intercom button(last or second to last on the right row of 5 buttons). It will display your intercom number and name if programmed.
Aug 14, 2010 | NorStar Meridian M7310 Phone
How do you change the time on a Meridian NT4X43 phone?
Press "Program" button
Press "Right Arrow" button until you see "Time and date set"
Press "Hold" button
Enter the current information
Press "Hold" button
Finally press "Rls" button and the correct information will show on display
Mar 15, 2010 | NorStar Aastra M522 Expansion Module,...
Meridian M7208. I managed to reset the default
Press feature *3, press the button you want to program back to speed dial, and press feature 0.
Oct 05, 2009 | Nortel Meridian M7208 Corded Phone
Meridian norstar want to delete and enter new numbers
If you are asking about Outside Auto Dial numbers (a "speed dial" number programmed to a button), follow these steps:
1. Leave the handset down
2. Dial "Feature (star) 1"
3. Press the button to be programmed
4. Enter the "speed dial" number
5. Press button under "OK" on the horizontal display.
The group of 12 buttons on top of an M7310 phone are Dual-Memory buttons, each can hold 2 speed dial numbers. When you press the button, you are using the Lower Memory location. When you press the Shift button (triangle-shaped button on the right) and the a Dual-Memory button, you are using the Upper Memory location. Good Luck!
Sep 28, 2009 | NorStar Meridian M7310 Phone
Nortel 1140E IP Phone, Expansion Module 1100 series not working
is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
Dec 09, 2008 | Nortel 1140E
Lands Phones Logo
15 people viewed this question
Top Meridian Lands Phones Experts
george  peters
george peters
Are you a Meridian Lands Phone Expert? Answer questions, earn points and help others
