Question about Microwave Ovens
2012 can am 450xc fuse box location - Microwave Ovens
How to find the fuse in 2007 magic chef over the range microwave
It is fused through the house fuse/circuit breaker box.
Feb 09, 2017 | Magic Chef Microwave Ovens
Where is the fuse box?
If no power fuse behind panel but may be thermal switch behind top vent remove and you can see it 2 black wires the spade may need to be tighten.This is the fire safety thermal. Test for 110 volt across to test.
Sep 30, 2014 | Samsung SMH1816S Microwave Oven
My RV lot lost power and my Domestic microwave hasn't worked since then. Its model DOTR12 CBIV and I am located near Omaha NE. Can you help?
Check fuse box for blown fuse bad fuse or fire ants or other inscects or insects nest in fuse box also wiggle an inspect wire for Burns or loose connections
Aug 07, 2014 | Microwave Ovens
Where is fuse box diagram 1995 dodge van
I believe this information can help you. It was got from Internet:
Most fuse boxes are located under the steering wheel of a vehicle but on some cars it can be in the glove box or under the glovebox but they may have hid it under the seat. On the 1996 Grand Caravan ES there are two fusebox locations.One is under the dash on the drivers side, you will need to remove the sound deadening panely by rotating two black plastic screws counter-clockwise. After removing the panel the fuse box is in plain sight. The other fuse box is under the hood, between the battery and the left fender. You will need to press the release at the rear of the cover and lift the hinged cover forward. This fuse box contains many relays as well as fuses. Be sure to replace the cover and ensure that it snaps down securely to prevent dirt and moisture from entering the fuse block.
Apr 24, 2014 | Microwave Ovens
Picture fuse box diagram
looking for fuse for washer pump will not shut off
Jan 07, 2014 | Microwave Ovens
Where is the magnetron tube?
the magnetron is not a tube,looks more like a finned box with 2 wires attached to it comming from a capacitor which could hold high voltage,and the fuse is attached to a small filter board right where the cord comes in
Dec 15, 2011 | Hotpoint RVM1325BW Microwave Oven
Where is the fuse located?
If the model number is correct, there is a small input line filter board with a 125V, 20 AMP line fuse inside the microwave. Its usually mounted on a small input line filter board at the point where the power cord enters the back of the unit. You will need to UNPLUG the microwave oven and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. I found this illustration at pcappliancerepair.com based on the model number you listed this question under:
http://pcappliancerepair.com/model-display.php
The line filter is listed as item 1420. The fuse will be mounted to this board.
You can purchase replacement fuses at any hardware store. You can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Slow Blow fuses are recommended.
If you have any questions, or need assistance troubleshooting, please post back and let me know. I hope you find this information helpful.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit.
Apr 24, 2010 | GE JES1290 Convection/Microwave Oven
Where is the fuse box located
there is a cartridge fuse under the outer cover of the unit,its a special 15 or 20 amp "ceramic fuse" you can get them at hardware stores,but if it opened there may be faulty components i.e. h.v cap./h.v. diode/magnetron, if another new one blows
Sep 12, 2009 | Microwave Ovens
Has no power
If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
thanks
Mar 18, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
