Question about Frigidaire Washing Machines
Washing machine will was but will not remove water
My Frigidaire clothes washer model FWSB7800DS0 will wash was but will not remove water or spin. The pump is not clogged I checked it. I hand drained the water out by lowering the hose but the knob (timer I guess) did not move past the wash cycle on its own. Even if I do push it down and turn it then pull it back on in the area at would drain/spin it does nothing. Is it the timer?? Is there so way to repair it instead of replacing it at $150.....
    Novelist:
    Champion:
  • 222 Answers
First thing check the lid switch it won't drain or spin if the lid switch is not working or broken highly possible. Also your pump may be ok but you still can have cloged hoses socks or small items can get in the hoses. Be sure and check hose from bottom of tub. Hope this helps. Be sure the stand pipe or outside drain is not clogged. Hope this helps. Check everything else before you buy an expensive timer.
Posted on May 07, 2013
    Sniper:
  • 79 Answers
Replacement cost will probably run you the same or more. Unless you can do it yourself. Sounds like the same thing we ran into before. All comes in one expensive part. timer and control knob
Posted on Jun 18, 2009
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
Not spinning water from machine completely..... have to remove some of the clothes and restart spin ......also has a squeak sometime. Thanks for your help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Oct 05, 2010 | Frigidaire GLTF2070DS Front Load Washer
I have a Frigidaire front loader washing machine. If there are only a few lightweight pieces of clothes, the water will not spin out. Also some of my clothes have spots on them after washing. What do I do?
For the odor, you might try running a cycle with a strong bleach solution (no clothes!!!). Leave the door open when not in use to air out.
Certain Frigidaire models will not spin out if the door switch is damaged or is defective.
Unplug the machine first before doing this!!
You can access the switch by removing the top (remove two screws from the back of the panel). To remove the switch, remove the two screws from the front of the machine where the door latches. Locate the switch and observe how the wires plug into it. Replace with new switch.
Jun 04, 2009 | Frigidaire ATF6000ES Front Load Washer
Water pumps in timer cycles but machine will not agitate or spin
Hii!! yo check your washer belt.if on the you have a tranny problem.good luck
Jan 16, 2009 | Frigidaire FWS833A Top Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
