Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Steam not coming out at all
The steam is not coming out forcefully as before. Now it is not coming out at all.
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
g
Posted on Sep 29, 2010
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: No steam
Take it apart, the heater is most likely plugged, use something small enough that you can put in the ports and clean them out. Once they are cleaned out, then use a mix of water and vineager, run that thru it for awhile to clean out the lines.
Posted on Feb 22, 2008
SOURCE: steam will not eject
Same issue with my model. Heated up but would not produce... I called it SED (Scunci Erectile Disfunction) My doctor prescribed him some lube, and it worked! Now days Im happy to say we share a heathy steamy relationship!
Say goodbye to SED forever with the help from lube! All you have to do is open up the unit, locate the circular brass colored button, apply a squirt of lube (wd-40), create a decent amount of pressure and play with the little button until you notice smooth in-out motions. Put the unit back together and BAM you two will be back to a hot and steamy relationship, just like you had when you first met! ;)
Posted on Sep 10, 2008
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
My Bissell Proheat Clearview Force isn't producing steam. The water isn't coming out of the tank
Either an electrical connection to the heater element is broken, or the element itself has become malfunctional. You'd have to dis-assemble the machine to inspect what exactly is the problem, then replace any non-functioning parts.
Oct 14, 2013 | Bissell 1699 ProHeat Clear View Upright...
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
While using, steam stopped coming out in force at the port levels in the head. Suddenly started high pitch whining, pressed button just above connection site and end flew off with great force pouring...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Nov 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My steam mop will not steam. the light comes on and it seems to heat up, but no steam comes out
heatman101
Oct 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The plastic housing the handle locks into has cracked. The handle comes out when pulled back with little force.
Sorry but there a very few parts for these...
heatman101
Aug 25, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam coming from tank
heatman101
oiu
May 20, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Steam Mop - Gray/ Purple Vacuum: light comes on but no steam...
heatman101
j
May 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No Steam after heating up
Sounds like the switch on the handle or the steam release solenoid on the steam chamber is faulty ,use a volt meter/tester to see if you have current to the solenoid when you turn on the switch.
Dec 02, 2008 | Euro-Pro S3325 Handheld Steam Vacuum
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Feb 20, 2008 | Black & Decker SV1000-4 SteamBuster Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
177 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
