Question about Samsung Cell Phones
Puk code I don't know the puk code for my Samsung s125g tracfone phone
How to unlock my sgh s125g
How to Unlock Samsung SGH-S125G?
*Please verify that your phone is prompt for the network unlock code while insert a non accepted sim card in this.
Follow the steps below to unlock this
Visit:- Official Samsung IMEI Permanent Unlock Important Select the Current...
Update the following Details
Brand Name:- Select the brand Name as Samsung
Model No or Name:- Select the Model No as
Select Country :- Select the Country from The Phone Purchased
Select Network :- Select Network on which The Phone Is Locked:-
Put E-Mail ID: Put your mail id
Update IMEI No:- After the success payment you need to open the mail id and login on to unlockninja by using the details send to our mail ID
After updating the IMEI the unlock process started on the same moment and unlock code will be delived to your mail id in least possible time.
How to use the unlock code
On the most Brand-Models the unlock code use as below
1) Insert a non compatible SIM card to your locked Cell Phone,
2) Phone will prompt for Unlock Code
3) Enter the Unlock Code you received.
4) Phone will be unlocked Now
How to Enter Unlock Codes on Samsung SGH-S125G?
Try the following Instructions:
Make sure "Airplane Mode" and "Wi-Fi" is turned off under wireless connections if your Samsung SGH-S125G is an Android device.
Method #1:
Insert a Non accepted simcard in your Samsung SGH-S125G and power on. Once finished loading your Samsung SGH-S125G will ask you to enter a code, enter the Unlock Code
Note: Non Accepted Simcard is any simcard not from the original provider
Method #2:
Go to the dial screen on your Samsung SGH-S125G as if you are going to make a call and press: #7465625*638*UNLOCKCODE# (8 digit unlock code)
Method #3:
Go to the dial screen on your Samsung SGH-S125G as if you are going to make a call and press: #0111*UNLOCKCODE# (8 digit unlock code)
Method #4:
Go to the dial screen on your Samsung SGH-S125G as if you are going to make a call and press #7465625*638*# Once prompted for code, enter the 8 digit Unlock Code.
If Phone says, "Code Accepted" or "Network Unlock Successful" or "Not Yet Personalized" your Samsung SGH-S125G is fully Unlocked
*If you are not receiving any signal after unlocking, make sure your wireless connections are turned on after unlocking the phone. Also pull the battery and restart Samsung SGH-S125G.
Dec 14, 2017 | Cell Phones
I have some how locked my Samsung TracFoneq and now I need a PUK code.
Samsung Tracfone: Locked Phone: Need PUK code:
"The PUK code is not related to the handset. It is rather associated with your SIM card. When you enable the PIN in your SIM card, every time you switch on your phone, you will be asked for your pin. At given number of tries provided by your mobile operator, that you have provided the wrong PIN (usually operators set it at 3 tries), then you came to the stage called PUK-blocked. To unlock, you would need the PUK code of the SIM card. The PUK code is usually an 8-digit code. This PUK code should have been provided to you when you purchased your SIM card. Some has the PIN-PUK code printed in the card body of the SIM card, while some attach it as a separate print out. Should your operator failed to provide this PIN-PUK code to you, perhaps, you would have to get it from your operator. Try calling their customer service. Just like the PIN, the operator as well could say how much tries do you have to successfully unblock the PUK of your SIM . The common number of tries set by the operators is 10 tries.. Got it?. What. You have to go to your provider to get the PUK code. If you enter it incorrectly THREE times you will forever block your card and all data on the card will be lost (phonebook) Your best bet is to visit a store rep BEFORE you block your card to keep your data intact.
Reference Link
Reset tracfone samsung sgh s150g Don know my puk how do reset Ask Me Fast
Jan 14, 2016 | Samsung Cell Phones
I have a samsung galaxy and a sim card that reads TF64SIMT5 V2 **********165746720 but the card will not fit into the sim card slot. Does this sim card not go to this phone?
I want to unlock my TracFone simcard for a Samsung? - I ...
www.askmefast.com > ... > Unlock
If you do not have the PUK card with you anymore the only way you can get the PUK code is to call customer service. I know your SIM ... Yes, your tracfone sim card will work on your unlocked samsung galaxy. If your getting an unlocked phone you`ll be able to use any sim card ... read more ... Tf64simt5 v2 fit what phone.
PUK TracFone Samsung S125G SIMCARD TF64SIMC4 V2 ...
www.askmefast.com > ... > Samsung
Need puk code for oberthur sim card provider to unlock samsung phone .... Tracfonesim card tf64simc4 v2 replacement ... your sim card will fit in. some smartphones now uses mini sim card like galaxy s3. .... Puk code for sim card tf64simt5 v2 .... I havesafe link wireless gov phone.phone is g440 says tracfone but it is safe ...
Which is the original carrier of my sim card in tracfone ...
Dec 29, 2015 | Samsung Cell Phones
PUK Code for Samsung SGH-S125G Tracfone
call your cellphone provider or find your original pachaging of the card. It is usually printed together with the stock pin code on the outer simcard part.
Oct 09, 2014 | Samsung SGH Cell Phones
Tracfone puk code
it comes from your sim / service provider
call customer care of your sim provider and ask them the puk,they will provide
dont enter any wrong digit
it may lock ur phone permanently
Dec 26, 2013 | Cell Phones
Puk code for samsung s125g
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater
Same Your No Problem will Solved
Nov 10, 2012 | Samsung Cell Phones
Unlocking samsung s125g
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Nov 10, 2012 | Cell Phones
What is the PUK code for Samsung T301G tracfone
My dear:
But:
Oct 15, 2012 | Samsung SGH-T105G
PUK Code for Samsung S125G
whatis the puk code to the samsung s125g
Jul 15, 2012 | Samsung Cell Phones
I was trying to reset my PIN code on my Tracfone Tg3o1g, but didn't know the old code, so it asked me for a Puk code and I have only 6 tries left! Please Help!
Don't worry about it,just contact your Sim card Network Provider and ask for your PUK code,they will verify your Name and Address then they will provide you easily.
Regards,
Please Don't forget to Rate my answer
Jun 08, 2011 | Samsung Cell Phones
Cell Phones Logo
73 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
