Question about Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Connect remote oarusb04g to toshiba mw24fm1
I need help connecting a universal remote
2 Suggested Answers
  • 1156 Answers
SOURCE: Remote contrl doesn't work for
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and proceed to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat to click the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassemble so re-assembly will be easier.
step 4Pull everything apart
Did you take a picture of the key pad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develop dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lens or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons
Use a small bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dish wash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons Once you have completed test with your camera you can use the remote.
Hope this will in solving the problem....
Posted on May 08, 2011
I need to program a Toshiba CT-9837 remote control and can't find the user manual online
Send your email address to me by Fixya, and get a copy of the manual by return mail.
Sep 10, 2012 | Toshiba CT-90326 Remote Control
Cannot connect toshiba 27a45 tv with philips universal remote
Often, universal remotes do not work as promised.
Go to www.replacementremotes.com to get a factory replacement remote
for your Toshiba 27a45 TV.
Jan 17, 2011 | Toshiba 27A45 27" TV
Need code to connect ot a toshiba vcr / dvd player
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Jun 12, 2009 | Philips Universal PH301S Remote Control
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Sony MW24FM1 either won't respond to DVD commands, or turn-off
Sounds like a bad power board. They have random meltdowns all too often. Usually the cause is an overheated transformer caused by power transistor short outs. Possibly sell it. Could get over $100 for it if sold online.
Nov 14, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Remote control
YES... Get a miracle remote, http://www.miracleremote.com/ for Toshiba and it will operate ALL of the functions like the original including access to the service menus.
Nov 02, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
NEED HELP PROGRAMING UNIVERSAL REMOTE CONTROL
rca d770 universal remote how do i program
Sep 03, 2008 | RCA Universal Remote Control
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Universal remote codes
NOT A SOLUTION, however my remote stopped working a couple months ago. I subsequently tried several universal remotes - none of these worked. An educated guess might be that the problem is NOT with the remote control unit, but rather something inside the set itself. This might also explain why the MW24FM1 you bought "didn't come with a remote".
Oct 23, 2006 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Can't programm TV MW20F11 tOSHIBA COMBINATION WITH ONELINK REMOTE CONTROL
An original type remote is available from 1-800- remotes or http://remotes.com for 27 bucks and change + shipping. I tryed to contact someone about the onelink and they are no longer around as I was told so this is your best bet. Good Luck
Jun 06, 2006 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Toshiba MW24FM1 24 in. TV/VCR/DVD Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
