Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Cant replace black ink cartridge as ink is at far right of printer so unable to open or move container to replace
  • seano89 Jun 18, 2009
    tried your solution but ink container still remains stuck at far right of printer
    now found solution to this annoying problem after pressing and holding stop button for a few seconds ink container moved to right but not far enough to open I then continued to press stop and it moved to correct position to open ans refill
    Problem Solver:
  • 26 Answers
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
tiuyaq4
Posted on Sep 04, 2009
    Problem Solver:
  • 13 Answers
I have the same printer, see it is anoying but sometimes you need to turn it off and back on and whn it done doing all it random movements push the button that has a drawing of a triangle inse a circle, it should put itself on the hole thats on top of the ink stickers
Posted on Jun 18, 2009
How to remove the ink cartridges?
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing. r_2.gif Open the printer cover. r_3.gif Press the fontb1.gif maintenance button. The print head moves to the black or color ink cartridge replacement position, the fontp.gif power light begins to flash, and the fontb1.gif error light begins to flash or remains on. When both cartridges are out of ink, the print head moves to the black ink cartridge replacement position first. After replacing the black cartridge, press the fontb1.gif maintenance button again to switch to the color cartridge replacement position. 98a04.gif r_4.gif Lift up the ink cartridge clamp as far as it will go. The cartridge rises partly out of the cartridge holder. Lift the cartridge out of the printer and dispose of it properly. Do not take the used cartridge apart or try to refill it. 98a05.gif r_5.gif Remove the new ink cartridge from its protective bag. Next, remove only the yellow tape seal from the cartridge. Do not touch the green IC chip on the side of the cartridge. 98a06.gif r_6.gif Place the ink cartridge into the ink cartridge holder, and then close the ink cartridge clamps. Do not apply excessive force to the cartridge. 98a07.gif r_7.gif Close the printer cover. r_8.gif Press the fontb1.gif maintenance button. The printer moves the print head and begins charging the ink delivery system. This process takes about thirty seconds to complete. When the ink charging process is finished, the printer returns the print head to its home position, the fontp.gif power light stops flashing and remains on, and the fontb1.gif error light goes out. 98a08.gif If you feel that my answer helped you then please give a vote for my answer.
Apr 04, 2011 | Epson Stylus C43UX InkJet Printer
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    How to open printer to change cartridge?
    In order to replace the cartriage, please follow the steps below:
    1 Keep the printer on.
    2 Lift the printer (scanner unit) until the scanner support keeps it open.
    The ink cartridge carrier moves and stops at the loading position unless the printer is
    busy.
    3 Squeeze the tabs on the cartridge lids, and then lift the lids.
    4 Remove the old cartridges.
    5 If you are installing new cartridges, remove the stickers and tape from the bottom of
    the cartridges.
    6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
    and the black cartridge is secure in the right carrier, and then snap the lids closed.
    7 Lift the printer (scanner unit) and push the scanner support back while lowering the
    printer (scanner unit) until it is closed.
    Sep 15, 2010 | Dell A920 InkJet Printer
    MP210 am unable to install ink cartridges properly
    1 Open the printer cover and prop it up with the support brace located on the right-hand side of the cover. It's similar to the way a car hood is propped open.
  • Step 2 Remove the black FINE ink cartridge from its container and locate the protective tape. Gently remove the protective tape used to cover the print head nozzles and electrical contacts.
  • Step 3 Insert the black FINE ink cartridge into the printer slot labeled "B." It will rest on a slight angle. Push the cartridge up and back until it clicks into place.
  • Step 4 Repeat the process for the color FINE ink cartridge, placing it in the slot labeled "C."
  • Step 5 Raise the printer cover slightly to loosen the support brace. Fold the brace inward and replace the cover to its closed position.
  • Step 6 A green LED light will flash on top of the printer. In about a minute, the LED stops flashing and displays "1." Once the "1" appears, you're ready to print.
  • Hope this helps...............Leadfoot44
  • Apr 15, 2010 | Canon PIXMA MP210 InkJet Printer
    Unable to install #40 & #41 ink into Canon PIXMAMP190. #40 pushes overhead clip out so far that #41 will not snap in.
    All printers will have the same cartridge number, with a sub-designation for the color, which could contain.. example: CK40BK ( Black ) CK40CY ( Cyan ) CK40MA ( Magenta ) CK40YE ( Yellow ), your color designators may vary, but your cartridge number will not. Recheck the #'s of the ones that do fit, throw away the ones that don't, they won't take returns on opened cartridges. When you get the right ones again, tear off the end tab of the box that shows any #, put it in your wallet for awhile... #40 & #41 will not work in the same printer.
    Toby White-Beebe
    Dell Certified Lead Systems Expert
    Aug 28, 2009 | Canon Office Equipment & Supplies
    Cant change ink cartridge on my Epson C91
    cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head by hand to replacement position.
    May 02, 2009 | Epson Stylus Photo 1400 Printer
    HP 932 RED LIGHT STAYS ON
    The light you describe is the ink light.
    When that light is blinking, try this.
    Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
    Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
    IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
    This printer will not work without both ink cartridges installed and full.
    You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
    Hope this helps!
    Aug 27, 2008 | HP DeskJet 932c InkJet Printer
    Can't find ink levels on my printer
    I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
    Aug 11, 2008 | HP DeskJet 5550 InkJet Printer
    Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
    155 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
