UPS backup broplem
MAKE: energ UPS MODEL: EN600R Dear sir, i have an above mentioned UPS but giving no backup what may be the reason? i already checked the battery it is ok works good with the other UPS and i also checked the 4 IFTS as well it is also in good condition then what may be the problem please reply soon Yours sincerely, Shrichandra.
  • 3 Answers
Did you press reset button and also check and see if there is a fuse, it may be blown
Posted on Jun 29, 2014
Benimur
  • 6966 Answers
SOURCE: UPS Backup
Appreciate the direct "Ask Me".
Initially, pls charge the battery outside of the UPS. Thereafter try again. If the unit will perform, it is just that the UPS is not capable of charging the battery from a flat condition since it is normally designed to cutoff below a certain voltage level, say 10.8 volts. In some instances, it could that the comparator circuitry that is responsible for trigerring on/off the inverter when the battery is at a certain level is defective. Due to the absence of a schematic diagram my end, it would rather be difficult to pinpoint the exact part unlike what was available for the Samsung SyncMaster 753S. If you would try to wing it, pls start with fusible resistors, presence of standby voltage (often 24V), charging voltage of >12VDC and a +5 logic voltage/supply. Pls exercise extreme care, the battery terminals have a relatively higher voltage (than 12) with respect to the chassis ground.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
SOURCE: UPS not charging
Sir, Our UPS is not charging at all. After following the procedure for shuting and starting up, it show battery charging 0%. The model is MGE Galaxy 3000 UPS and also cooling fan is going to falt mode .with best regards
Posted on Dec 01, 2008
gotgeek2
  • 565 Answers
SOURCE: APC Backup UPS Model # BK200C salvageable?
Yes, but the battery may not be any good, though, and trying to charge it may damage the charger. A new battery is about $20. The surge suppressor will still work without the battery as long as it is connected to a properly grounded 3-wire circuit. If you decide to take a chance and charge the old battery, take precautions like keeping a watch on it should it explode or catch fire. Not trying to scare you, just looking at worst case scenario.
Posted on Jan 27, 2009
ghoff1
  • 167 Answers
SOURCE: Nexxtech UPS Battery shows full charge but won't stay on
had same problem! i discovered that the unit was defective,sorry if this is the case. good luck!
Posted on Feb 13, 2009
  • 33 Answers
SOURCE: UPS Switching off while working
Hi kumaraswamy5,
it seems that either the UPS is connected to an outled which isn't grounded properly or the battery inside of the UPS needs a replacement.
On APC's website you can find the compatible batteries for your device and where to order them. Replacing the batteries is very easy so don't be afraid of that!
Greetings from Germany,
noris017
PS: Please don't forget to rate this advice after you've tested it out! Thanks in advance and have a nice day!
Posted on Feb 25, 2009
UPS backup problem
Hi Shrichandra,
Make sure that the battery you are using from the APC UPS is the correct one for the EnerG UPS, just because it fits doesn't make it the right one.
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 14, 2014 | Computers & Internet
Ups luminous 800VA not giving output in dc and ac
The battery may be depleted, the internal transformer shorted, the fuse may need to be rest. Check all of the above.
Mar 15, 2014 | InterAct Accessories Fenton 800VA Line...
Where can I get schematic for this unit?
Apperently APC has a policy against releasing schematics
Read
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | APC Smart-UPS DP 6000 UPS System
My ups is not giving backup?
The main reason for not giving backup is improper charging or insufficient charging. Or if the UPS is about 18-20 months old, the battery is unable to give backup. or these are not the cases, the wires inside the ups, above the battery ,connected to the +ve and -ve ports on the above or side of battery are not properly connected or are loosen. try to tighten them with yourself with a plier or goto a shop for a better result. Hope this will help. Thanks for using Fixya.
Nov 17, 2010 | Computers & Internet
Numeric UPS not working
when i on my ups it is indicating to fault showing a red light and giving a long beep sound and no output voltage is coming from it do i need to configure?please help me
May 10, 2010 | Opti -UPS BackUp-Time 525BT (UPS-525BT)...
Ups
filter cct burn out so, kindly give e filtter cct of 800 apc ups.
Sep 16, 2008 | Computers & Internet
UPS is not showing AC light on i.e Green light
It does not look good for this unit.
Time to upgrade, go bigger. Maybe this unit is too small for you system. Most likely a 1000VA will solve your problem.
Sep 10, 2008 | APC Back-UPS CS 500VA UPS System
UPS not charging
Jul 02, 2008 | MGE Galaxy 3000 UPS System
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
