Washer frigidaire GLTF1670A
My frigidaire GlTF1670A makes an extremly loud banging noise specially on final spin. acc to sears tec i need a new drum and possibly a new pump ??
  • 4 more comments
  • anpazi Jun 18, 2009
    just found out the noise only happens when machine is loaded not
    when machine is empty. does this support your solutions of a new drum ?
    thank you
    thank you so much. it is the ASO model.
  • anpazi Jun 21, 2009
    Thank you very much for trying to help me. The technician that came out and looked at the problem appeared more interested in overcharging than in fixing the problem. Therefore I have decided to try and fix it myself. I noticed that the "tub leveling shock absorber" on one side of the drum appears to be leaking the grease that I believe is inside the absorber. The other shock absorber has no grease on the outside of it whatsoever. Should this be happening or is it possible that the shock absorber (since it is called "tub leveling") may be what is causing the problem? Also I looked on a parts diagram for the "link" you mentioned when you had this problem but could not find it. Could you please describe it in more detail. Thank you very much for all your help.
  • anpazi Jun 22, 2009
    thank you . I have looked for the link between the motor and drum
    on the diagram that you have mentioned , but could not find it ?
    is there a part name or could you be kind enough to describe it ?
    thank you again.
    i have spun it by hand abd it does not make a sound just like when
    there is no weight in the drum.
    thank you very much, will let you know if it worked.
    Problem Solver:
  • 13 Answers
You need a new drum, wich is pretty much like buying a new machine
Posted on Jun 18, 2009
  • 3 more comments
  • ss4769 Jun 18, 2009
    what is the model exacly is it the AS/ASO/or/AS1 if you can get down and dirty you can take it apart and check if a linkage is broken because if the noise only occurs when it loaded its no the drum. you can find a great diagrams of the inner parts and prices at sears parts center. i had the same problem and it was the link between the motor and drum that was making the noise because it was cracked.
  • ss4769 Jun 22, 2009
    it could be a reson because it should not be leaking,have you looked for othe slightly carcked or broken thing? here is the link for your washer machine: http://www.searspartsdirect.com/partsdir...
    mine was a 4 year old whirlpool top loader so its probably differnt, yours uses a belt drive system.im fairly confident it is ither the shock absorver,a spring, a loose belt or the motor itself. have you tried spining it by hand to kinda locate a general area of where the noise is coming from.
    you should buy the shock absorver because since it has no presure thanks to the leaking grease it probably cant stop the machine from bangin against the side when its loaded like its supposed to
    try changing the leaky shock absorver
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Very loud noise during spin cycle - drum still spinning at normal speed. sounds almost like a broken belt - are there more than one belt?
only one belt on machines, ur looking at one of the following
  • loose counter weight
  • something stuck in drum, eg bra wire, sock
  • bearings failing
  • broken shaft
  • machine not level maybe?
Sep 23, 2010 | Frigidaire GLTF1670A Front Load Washer
The drum is loose when the washing machine is not in use. When it's in use it makes a loud whirring noise like a train going through my house. This happens on an empty load as well. The machine is a front...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
LOUD BANGING AND SCRATCHING NOISE ON SPIN CYCLE
Urgent stop using it !!!!
The drum suspension is coming to bits , get someone in to look at it before the drum comes through the side of the machine
Jun 16, 2009 | Frigidaire GLTF1670A Front Load Washer
Very loud noise during final spin
Possible your spider arm, which you cannot see, has come loose, or has broken. Its a major fix.
Mar 11, 2009 | Frigidaire GLTF1670A Front Load Washer
Noise when ge washer put in spin mode
this could be one of two problems.
The first which is fairly cheap to repair would be to check the carbon brushes in the motor, they may need replacing, especially if your washing comes out wetter then it should.
The second is the bearings on the drum which is more expensive to replace and would need to be done by an engineer.
Nov 16, 2008 | Frigidaire GLTF1670A Front Load Washer
Makes a noise like there are rocks or coins when it spins
If it is thumping... you have a broken spider on the inner stainless steel drum. Major defect with this machine. You'll need to call to get a new washer tub assembly... comes complete with inner stainless steel drum and outer plastic drum already assembled and ready to install. Good luck.!
Jul 01, 2008 | Frigidaire GLTF1670A Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
260 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
