Question about Hozelock 2490 Auto Reel 20m Hose 12.5mm
Leaking from connection inside
Leak on connection where pipe fitting on drum
Installed new tub drain linkage assembly water still leaks by
You need to use clay party to seal around the fitting 3_25_2013_1_25_38_am.png
Mar 24, 2013 | Home
Leaking jacuzzi jet
The workings of a bath jet...From the inside of the Bath there is a wall fitting that threads from the inside of the tub into the jet body located on the outside wall of the tub.
If the jet is leaking at this point behind the tub then you should take the wall fitting out of the tub and put a small bead of 100% RTV silicone around the flange of the wall fitting and reinstall it.
If however, the leak is from the PVC piping going into the jet then you will need to replace the jet.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Kohler Home
It is leaking around where the pipe inserts into the toilet
try a new o ring inside the the tighten nut which is attached to the water pipe
Dec 17, 2012 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Rhepre 40-4 wtr heater leaking from cold water intake
Firstly, don't confuse condensation on the pipe with a leak. The cold water inside the pipe makes the pipe cold. The warmer air around the pipe causes condensation to appear - much the way a glass of cold water "sweats" on a table in a warm room.
Next, determine exactly where the source of the leak is. If it is at a soldered or threaded junction of pipes or pipe an tank, you should be able to solve it - if you know how to solder.
You'll have to power off the tank at the circuit breaker (or shut off the gas supply if not an electric type) before doing anything else. Next, shut off the cold water supply to the tank. This valve must be on the supply side of the leak. If the leak is ahead of the valve, you might need to shut off the water to the entire building. Then, open the closest hot water faucet. Finally, lower the water level of the tank by draining the tank from the bottom valve (you'll need to connect a garden hose to it and run the end to the outdoors, shower drain, toilet, etc.). Keep in mind - the water will not drain "up hill". That means the end of the hose must be lower than the top of the tank. You do not need to drain the entire contents of the heater unless you need to physically move it (or if it is a natural gas or propane type - as a licensed plumber or pipe fitter will be required to disconnect / reconnect the fuel line). A few gallons of water should be enough to allow working on the pipe without causing spills.
Disconnect the cold water supply pipe from the tank - above the source of the leak. You may have to do this by un-soldering the nearest pipe coupling with a propane or mapp gas torch. Soak a thick cloth in cold water and wrap it around the pipe at the tank's inlet to prevent the heat from the torch from damaging the plastic inlet fitting inside the tank. If the inlet connector is melted or damaged; the entire tank must be replaced. Additionally, you might need to unsolder the hot water piping to get better access to the cold water pipe. Only disconnect as much as needed to do the job.
Once the pipe(s) are disconnected, remove the section of pipe that mates with the leak. You will probably need wrenches to unthread pipe sections or fittings so that you can carefully inspect the male and female threads. Fully remove the pipes & fittings and obtain replacements as needed.
You might want to think about installing unions on the hot and cold water pipes. These will make future removal of the tank very easy with no need for soldering. Doing this will increase the time it takes to do the job this time, but simplifies tank removal in the future. You're already into this job - and its only few more extra steps.
Before reassembly, you should provide several wraps of teflon tape around the threaded portion of all male pipe threads. Telfon tape is highly suggested as it is clean and very easy to work with when compared with pipe dope that is applied with a brush. Carefully thread the pipes into the fitting(s) on the tank hand tight. If you are presented enough pipe or fitting to hold the tank inlet fitting, do so with a wrench. Use a second wrench to fully tighten the pipe into fitting. If there is no way to hold the inlet fitting, use a wrench to tighten the pipe about an additional full turn. Always use two wrenches to tighten pipes into fittings when possible. Make up any other threaded fittings (unions, etc.) and pipes as needed. Dry fit the copper pipes together - cut long pieces and replace short pieces of pipes as needed. Once all the pieces are are the correct length and fit together properly prepare for soldering. Clean the outside ends of all copper pipes and insides of couplings and connectors to be soldered with emery cloth, sand paper, or wire brush tools designed for expressly this purpose etc. until they are fully scuffed up and are bright and shiny. Wipe any dust and debris from the pipe with a clean, dry cloth. Try not to touch the cleaned parts of the pipe with bare hands. Apply a light coating of soldering flux to the cleaned ends and fit the pipes with couplings together again like the dry fitting earlier. Place a wet cloth around the pipes nearest the inlets (as before when removing the pipes) once again.
Heat the couplings and fittings one at a time with just enough heat to cause the solder to be wicked into the fitting. It is important not over heat the fittings or pipes. Be sure to let solder flow all the way around the pipes and into both ends of the coupling to ensure a complete solder seal both in and out of the coupling. Wipe away excess solder with a wet cloth to keep your work good looking. Once one fitting has been completed, go to the next and repeat until all fittings and pipes are soldered and clean. A good soldered joint should have a ring of solder visible all the way around the pipe inside the edge of the coupling.
If you've never soldered before, you should practice before doing this repair. Botched soldered joints could result in water damage and additional repair work that is greater than the original problem. Of course, a licensed plumber will make short work of this job and is an excellent alternative to DIY when money for the repair is available.
Dec 18, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Have a brake leak in the driver side rear inside the hub.How do I fix it
Open up the bonnet and look for round black color device fitted near the driver side inside the engine bay. There will be pipes fitted to it and a brake oil reservoir on it. This is the brake master cylinder and round thing is brake booster. Any one of these is leaking and brake oil being very thin, is seeping inside your car. Take a look at the end of the pipes fitted to brake master cylinder, if anyone is leaking, tighten them. Still there is leak? your need to replace the master cylinder.
May 03, 2011 | 1996 Volkswagen Jetta
Appears to have a gas leak inside the roller drum...is this repairable
Gas leaks can be repaired. A leaky pipe fitting will be less expensive than a faulty gas valve assembly. Locate the source of the leak and replace or repair.
Eric
Jun 11, 2010 | Kenmore 74602 Gas Dryer
My 1042 Power Humidifier has water under the PVC pipe leading from the unit into the drain. Does that mean the unit itself is leaking water?
Hi, if the unit is leaking and it looks as though it is coming from the PVC pipe, more then likely its leaking at the unit its self where the pipe connects. Water will run down the pipe and drip down line. Dry it off and put your hand around where the PVC pipe screws into unit. Unless the pipe is cracked, this is where the leak is. If the fitting is a male or female threaded PVC fitting and a piece of PVC pipe that goes to the drain, you can repair this very easy. Just cut the pipe near the fitting with a hacksaw. Unscrew the fitting that goes to unit. Go to a hardware store like Home Depot, take the old fitting with you and buy a replacement. Buy a coupling, a small can of clear PVC glue and a small can or tube of pipe dope to put on the fitting threads. Screw the fitting in first and make sure it has pipe dope on it, get it tight with pliers. Take the pipe and coupling and glue it on the pipe. Put glue on the other end and slide it in the fitting that was where it was leaking before. Hold it in place for a few seconds. Once you put the glue on, be ready to put it together as it drys super fast and you cant take it apart once it sets. Very easy to repair and the parts cost pennys. Keep me posted. You can do this and will learn about plumbing! Good Luck.
Shastalaker7
Jan 24, 2010 | General Filters 1042-LH Humidifier
Leaking from what looks to be the water inlet connection...however we have changed the hose,including putting a sealant around where it connects, but it still leaks.
it could be that the nut on the pipe connection tap is leaking and not your pipe fitting try tighting the nut just a small amout do not over tighten as you will crush the copper pipe and it will leak more
Jan 16, 2010 | Hotpoint Ultima WF860 Front Load Washer
My master bathtub is leaking
Yes the weight of someone in the tub plus the water can push the tub down far enough to cause the leak.
Unscrew the flange in the tub that holds the drain to the tub. Get some plumbers putty and make a bead to fit between the tub and flange.
Make sure the rubber gasket is clean ..use a bit of plumber's putty on this as well. Get an assistant to stand in the tub while you snug things up.
Snug it up tight.... replace if the threads are stripped as you said.
Plus if your house is less than a year old, I'd talk to the contractor/builder if possible about warranty work...most reputable builders will cover their work for the first year.
Jun 22, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Coolant leak on back side of engine. 94 susuki sidekick 4cyl 4x4
The back side of the cylinder head has metal fitting/pipe connected to a hose that goes to the heater system inside the cabin, the hose sometimes cracks off just behind the clamp holding it to the metal fitting/pipe.
Jun 19, 2009 | 1994 Suzuki Sidekick
Hozelock 2490 Auto Reel 20m Hose 12.5mm Logo
44 people viewed this question
Top Hozelock Garden Experts
richie46
J Walsh
Level 1 Expert
Bill Boyd
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
