Question about GE Profile Performance WPSF4170WAA
Ge wpsf4170w1ww will drain after wash but will not advance ,advance manually and work untill the rinse cycle drained and stoppped again
Washer will not advance after draining from wash or rinse .had to manually advance to get it to rinse cycle
SOURCE:
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
SOURCE: GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
Most likley it's the drain pump! check the wiing and pump
Posted on Jul 09, 2008
cbrown801
  • 3 Answers
SOURCE: washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Posted on Mar 30, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
SOURCE: Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Posted on Oct 02, 2009
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Two year old Whirlpool washer started failing to advance from the rinse cycle to the spin cycle a couple of weeks ago. However, the water would drain through and run until you manually advanced the system...
Hi, I just want clarification. Is the washer filling to a point when it starts draining the water before it starts to agitate? If this is the case, check the end of your drain hose and make sure that it is as high as the top of the washer. Make sure that where it goes into the drain pipe that it is a loose fitting so that air will **** back into the drain hose. Please let me know if I have given you the right information or if I have missed what you are describing so I can assist you further.
Thank
Vic
Jul 13, 2009 | Washing Machines
Frigidaire top load washer won't rinse
this can be two issues. One could be the control knob. there could be a malfunction here. secondly, you may have a faulty water valve assembly. the relay or solenoid may need to be replaced. i would start with the control knob.
Mar 13, 2009 | Washing Machines
Washer constantly draining after first cycle
For the machine to keep filling it would indicate that there is a siphoning problem. Check the outlet hose is not running along the ground, it has to rise up then loop back down or the water will just run straight down the drain. If the problem only happens after the first pump out it would indicate the end of the outlet hose is lower than the drum or there is no air break around the outlet hose. (The stand pipe should be larger in diameter than the hose from the machine).
http://selfix-uk.co.uk/under%20sink%20plumbing.html
May 01, 2017 | GE Spacemaker WSLP1100D Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
WHRE5260E1WW (GE washer) will not empty after wash or advance to spin cycle..then after a while shuts down
try this , open washer do you can look inside , theres a DRAIN MOTOR PUMP with 2 hoses connected to it , have a bucket ready and some rags , your gonna take out the drain motor, that could be clogged and not able to continue with the drain rinse cycle. clean the impellers of drain motor , reinstall , and try again , hope this helps , please rate and thanks AJ
May 09, 2008 | GE WHRE5260E Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
