Question about Sony MHC-GS300AV CD Shelf System
60watt cd changer Sony
I have a 100 watt 60 cd changer.I get"protect push power." I m ready to dump it the garbage. Is the part inexpensive and can i do it.
  • 436 Answers
SOURCE: LBT-XG500
Power protect tends to mean the main power amp chip has "blown" and needs to be replaced. It only costs about 20 dollars (10GBP). If you are handy with a soldering iron it is easy to do (after you get the thing to bits !) It is the big black thing on the big heatsink inside. The Sony part number is STK442 - 130. Seems a waste to throw the whole thing away for the sake of 10 pounds !. Hope this helps. Nik Howell (nh@totalise.co.uk)
Posted on Jun 16, 2007
SOURCE: protect push power
hi, everytime i switch on my sony hi fi it the display screen says protect push power. It won't let me do anything not even put cd's in. If you could help that would be very much appreciated.
Posted on Oct 27, 2008
Luis2584
  • 7 Answers
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Posted on Dec 19, 2008
SOURCE: sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Posted on Feb 11, 2009
SOURCE: sony 60 cd changer mhc-gs300av
The audio amplifier IC is damaged and need to be replaced
Cdx-705
Most cd changes only work with like brands. Sony with Sony .jvc with jvc. Find a manual for a brand new model on google or the the manufacturer and see if it has a problems section
Dec 27, 2013 | Sony Cdx-705 10-disc Intensified Shock...
Need a good 500 watt cd player not sure what to buy
Before you go off on a wattage hunt you should learn what that means.
Search the web for subjects such as "amplifier wattage vs speaker wattage" for starts.
Don't buy into what manuafacturers CLAIM for wattage if it ADDS all the channels together and FAILS to specify a bandwidth and an acceptably low distortion figure. REPUTABLE makers specify watts per channel, all channels driven at no more than X distortion (typically well under .1%) and, at minimum, across the audio bandwidth or 20Hz - 20kHz.
Any garbage cheapo amp (meaning most shelf systems or all-in-one packages) can put out a lot of dirty power which will strain THEM and possibly kill your speakers. CLEAN POWER is what you want.
Dosome reading and search the web for whatever you are considering, and add the word 'scam' to the search. Get opinions from actual owners. There are a lot of unscrupulous people out there selling garbage to people on the streets.
Aug 22, 2011 | JVC HXC6 500-Watt Stereo System with 5-CD...
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
Sony cdx-45 what is e99 then swichts off ????can you help...
i have the same cd player. i get the error if i try to play a cd to quickly after turning it on or loading cd's.
the only way i have found to clear it is to disconnect the power (red and yellow wires) and leave disconnected for 60 seconds
Jan 06, 2009 | Sony CDX-454RF 10-Disc CD Changer
Converter for my sony grand wega 60" to work in the U.K.
The specifications for this set list the power consumption at 250 watts so allow for a little extra and go with a 500 watt converter. Also, make sure the converter will change the UK's 50Hz power to the 60 Hz power required for the set. To be exact, the converter must change the UK's 230 volt 50 hertz power to 120 volts (100 will do) 60 hertz. Do NOT attempt to run the TV on 50 hertz power as it is likely you will damage the set
Nov 29, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
5 CD Changer won't work
my rca 5 cd changer skips on all cd's?
Jun 26, 2008 | RCA 100-Watt Stereo System With 5-CD...
Protection displayed and shuts off
The protect message indicates that the output amp section has a problem. Normally this requires the replacement of the output transistors or the output amp pac. Expect the repair cost to be about $20-$60 for parts plus the local labor rate.
Dan
Mar 22, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
Sony 60 cd changer mhc-gs300av
Nov 21, 2007 | Sony MHC-GS300AV CD Shelf System
Sony MHC-GS300AV CD Shelf System Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
