The door lock flashes constantly - Indesit WIA101
Somebody used the washing machine wrong way and now all the time the door lock flashes constantly.
Additionally i dont need to set the program every time i want to do the washing cause there is already program set, i just put clothes inside, close the door and press start.
I restated washing machine few times, unplugged it and nothing works.
It is not a big problem but this light is playing my nerves, please help with the advice what to do!
  • lou_806 Apr 13, 2009
    I have the same problem with my machine and the light has been driving us crazy for 2 years now! Did the above sugggestion work for you?
  • willer01
    willer01 Jun 09, 2012
    Door lock Flashing Means its Finished the Program.. DoorLock is Released..!
    Solid LED.. Means Door is Locked.
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Posted on Aug 23, 2008
I have an indesit washing machine model WIA101 that needs draining in prep for disposal and i don;t know what to do
front loader direct drive
drop the drain hose to the ground let gravity empty the water
can be dumped as is
no oils or asbestos in its design
Jan 22, 2017 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 09, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine will not drain and carry on with full cycle
Same problem - changed module with no result. Looks like the water temperature thermistor...
Jun 12, 2008 | Washing Machines
Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Indesit W123s - Hates Us
first thing to do is to make sure the washing machine is not siphoning. sometimes if a washing machine is bringing in water its all so draining it ,known in the trade as siphoning. the drain hose must be higher than the tub?? Unplug your washing machine from the wall socket for a minute or two and plug it back in to reset its micro. to me it sounds like a main board fault. I think you might find that it still maybe under warranty. ring a Indesit service agent and get some advice.
Aug 17, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
1,034 people viewed this question
Top Washing Machines Experts
