Question about NEC Display NP-V260X 3D Ready DLP Projector - 1080i - HDTV - 4:3 - NTS
NP-V260X No power will not turn on
Nec v260xg image alignment problem
Try the Keystone correction function to correct the trapezoid distortion.
May 02, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
NEC V260XG temperature error. How to Stop??
check the thermostat; it appears that either the thermostat is not working properly, or is not set right or damaged
Apr 23, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
The most common cause is dust inside the projector that leads to overheating & auto shutdown. If you have an air compressor you can use the blow tip accessory to blow as much dust out as you can without taking apart the projector. You may get by using a can of compressed air available at Walmart, etc. electronics section. Concentrate on vented areas & where you can see or hear any fans. Do this outside so it doesn't make a mess. If you know how to take out the lamp there's usually close access to the main cooling fan through the lamp compartment, blow air through there & it will follow the right path to exit correctly without blowing dust all over the inside.
Apr 12, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
How do i reset my lamp timer on my nec v260
go to menue / reset/clear lamp hours,
all the buttons needed are on the box, push menu & with the cross navigate & with enter confirm selection, exit gets you back at any time, on the nec/support website you can get the np-v series manual
good luck
Oct 30, 2014 | NEC Display NP-V260X Dlp Projector - 3D...
Change the bulb on NCE v260X and I still have white snow flake when I turn it on
Have you adjusted the contrast and Keystone. A new bulb should be plenty bright. Maybe clean the lens. There is in some types of Projectors a color wheel inside this can become dusty. But not often if you keep the filters in place and clean them. This could cause a snowy picture as well. Hard to say without actually seeing the picture to say what the issue could be. But these are some of the stronger possiabilities.
Sep 30, 2014 | NEC NP-V260 DLP Projector
NP Q45 Blinking power supply
If it's the right-most status indicator on the laptop (a circle with a line through it), blinking means the computer is in Sleep mode. Just move your mouse or hit the enter key and it should wake up.
Jun 12, 2014 | Samsung Ac Adapter Cord For Np-q40 Np-q45...
Mesin saya canon np 6650 II, nesin tidak jalan, pada layar monitor tertulis E001 ! turn the power on again, bagaimana solusinya?
PAGI gan saya mau tanya foto copy saya NP6650 II di monitor ada tulisan nya 002 ! TURN THE POWER ON AGAIN BAGAIMANA SOLUSINYA TRIMA KASIH
Nov 11, 2010 | Canon NP 6650II Copier
Canon NP 6230 copier - what does error code e244 refer to?
you have a scanner or lens problem look in the glass when you turn it on both the scanner and the lens should move some
Jan 13, 2009 | Canon NP 6230 Copier
NEC Display NP-V260X 3D Ready DLP Projector - 1080i - HDTV - 4:3 - NTS Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
