Question about Vehicle Parts & Accessories
Chev optra one day light not working?
    Master:
  • 710 Answers
Check bulbs.
Posted on Sep 01, 2014
How drain rhe annfreeze or of 2004 chev optra radior
2004 Chevrolet Optra Coolanat Flush: Where Do I Find the Drain ...
https://www.2carpros.com/questions/2004-chevrolet-optra-coolanat-flush
  1. Cached
  2. Similar
Mar 10, 2014 - Where do i find the drain plug for the coolant flush. Reply 1: Its on the bottom of the radiator. If you cant reach or see it just take off the ...
drain rhe annfreeze or of 2004 chev optra Google Search
May 18, 2017 | Cars & Trucks
HI WE HAVE A CHEV OPTRA 1.6 2009.WHEN COLD IT RUNS FINE BUT WHEN HOT IT MISFIRES AND ENGINE LIGHT IS ON.WE DID REPLACE COIL. PLEASE HELP
engine light on ..any other fault codes
changed coil ..still the miss fire
could it be cam shaft sensor or crank angle sensor
are plugs leads and injectors working ?
Nov 08, 2016 | Cars & Trucks
I need to know where the fuel filter is on a 2004 chev optra
Hi there:
On your vehicle, the fuel filter is inside the tank and cannot be replaced seperatly.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Jul 06, 2012 | Chevrolet Optra Cars & Trucks
I have the engine warning light lit up on the dashboard, but the vehicle still seems normal. I am about to drive to JHB from Durban in 2 days time. Should this be checked out immediately? It is a...
check engine lights can come on for a variety of reasons anything from low oil to a **** miss fire or a low voltage reading on a scencer i would have the computer scanned for any codes and cleared.
Dec 16, 2010 | Chevrolet Spark Cars & Trucks
I need rain guards for my car optra chev 2004 why is hard to find them
Hard to find because of the way door sits to the body.
You may not find any are made.
May 17, 2010 | Cars & Trucks
04 chev optraheadlights not working. new switch and drl module. drls working .no high or low beam.relays and fuses good
apparently there has been a Daewoo technical bulletin that says problems with low beam and DRL on some 2005-6 Optras caused by a melted wire in the s201 splice pack on the IP harness. If I knew where that was I might be able to fix the same problem on my Optra. Tried new light switch but no success.
Jan 16, 2010 | Daewoo Nubira Cars & Trucks
04 chev optra i have no daytime running lights and no low beam but the high beam works i have swaped fuses and new bulbs what else can it be
I have a similar problem with my 2005 Optra 5 - daytime running lights are hit/miss. About 3-4 years ago, the alarm started activating itself - FREQUENTLY. Turns out it was corroded wires. Now this. (Take heart - my Corolla had a similar problem - bad sockets - bulbs burned out faster than they could be replaced. Toyota never did admit responsibility.)
Road Safety Recalls Database
Print this Page
Transport Canada Recall # 2007315 Recall Date: 2007/09/28 Notification Type: Safety Mfr System: Lights And Instruments Manufacturer Recall Number: 07240 Units Affected: question.gif 33,865 Category: Car Recall Details: Certain vehicles may experience a loss of headlamp low beam or Daytime Running Light (DRL) function as a result of a melted instrument panel harness connector. Low beam failure would lead to reduced visibility during hours of darkness. DRL failure may render the vehicle less visible to other motorists and pedestrians during daylight hours. Both cases could lead to a vehicle crash with injury or death. Correction: Dealers will add a direct connection splice clip to the headlamp low beam circuit in order to bypass the faulty connector. Make Model Model Year(s) Affected CHEVROLET OPTRA 2004 2005 2006
Sep 21, 2008 | Chevrolet Aveo Cars & Trucks
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
