Question about Garden
2348ls will not move forward
2348ls will not move fortward
Power seat
Most Fordicon1.png products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
The long term fix is to remove the seat, disassemble the seat belt guide and rail, and usually replace some parts.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works besticon1.png to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
There's no guarantee that it won't jam again if you move it all the way back or forward, but once you find the right position to hold the seat latch in while moving the seat, you should be able to re-adjust it where you need it to be.
Oct 21, 2013 | 1998 Ford Expedition
Driver's side power seat won't move back but will move forward, up and down
If this is a 1994+ Ford, it might be that the seat belt latch is the problem. Most Ford products are designed so the seat belt latch by the center console moves with the seat. The bottom of the latch rides on the seat rail, and with time sometimes it builds up a little play on the rail. As the seat moves forward or back, the seat belt guide often tilts forward or back, just a bit, on the rail, and gets stuck. So you can move forward or back just a bit, but then it jams and you can hear the motor, but can go no further.
But the short term solution is often to simply hold on to the seat belt latch and rock it forward and away from the seat as you try to go forward or back. Or, sometimes it works best to rock it backwards and away from the seat as you try to move forward or back. It all depends on which way it is binding.
Sep 09, 2013 | Computers & Internet
Electric seat won't go forward or back. Sounds like it's trying
Aug 22, 2013 | 2003 Ford Expedition
Hercules Helicopter doesn't move forward much
My Hercules is a 3 channel heli,and I will try moving battery forward. On my SYMA s107 I turned the back blade upside down and got a dif style blade. It now goes Forward Great.
Jun 01, 2013 | Toys
Car cannot move forward while engine running
check transmission fluid first.if its low add to get correct level.if transmission fluid look dark smells burnt replace fluid and filter.if car still dont move forward.looks like you have bad worn out forward clutch plates and seals.also bad transmission oil pump.you need a overhaul or new transmission.
Jan 01, 2010 | 1995 Toyota Corolla
Forward button
Im assuming this is a cheatcode for a specific game, meaning that you move the stick forward as if you were to move your character forward. If this isnt the case please let us know what game you are trying to use this on.
Jul 11, 2009 | Sony PlayStation Portable (PSP) Console
Connection
if it is a wireless connection try moving closer to the router or look up a thing call port fortwarding...basically making a direct connection between your PS3 and your router.
Jun 05, 2009 | Video Game Consoles & Games
My front seat will not move forward. It will recline, move up and down but it will not move forward. I've tried reseting the seat positions but nothing seems to work. my seat wont move forward is there a...
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
Jun 02, 2009 | 2004 GMC Envoy
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
