Staples get crooked - Office Equipment & Supplies
Brad nails crooked in bostitch
Have you inserted the correct Brad Nails? What is the code of brads you have inserted? Is the tool jammed?
Solent Products Air Nailing and Stapling Supplies
Mar 21, 2013 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley light duty staple gun loads and shoots but staples not coming out. nothing jammed as far as I can see. Should I open it up and have a look at the interior? Thank you Denise
It sounds to me like you must have a staple that has seperated and probablygot stuck in staple feed shute' I wouold carefuflly remove side plate and see if there is a staple in there crooked or if their is is small metal chip left over from manufacture.I hope this helps you.THANK.
Apr 07, 2011 | Stanley TR40 Light Duty Tacker
Swingline heavy duty stapler wont staple??? staples come out crooked
I'm having the same problem,...... Ugh,.. The stupid lil bendy thing that u put in the groove for the staples that u attach to the spring took me forever to put in place.. And I think it make have gotten out of place when I finally kept it in place long enough to close it,.
Aug 05, 2010 | Black & Decker 5700 Powershot Forward...
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Paper jam
look for debris in the feeder very common to see staples, and paper clips in the paper path
Mar 29, 2010 | Canon Office Equipment & Supplies
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Instructions on unjamming swingline electric stapler model 270; jam is at the front of the stapler; staplers come out either broken, flaten or crooked and does not secure document.
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Mar 03, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Paper feeds crooked and will not go through printer
Sounds like you have something jammed in the paper path. Take out the paper tray, and the toner cartridge, and look for scraps of paper, a paper clip, staple, stray cat, or other item in the path.
Mar 01, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Stanley Sharpshooter electric staple/nail gun-Hi-Lo knob moves
This is an ongoing problem with this tool. Between inadvertently moving it while using it and the constant rebound of the tool, the setting gets changed. The only suggestion I have is to duct tape the setting wheel into position.
Feb 12, 2009 | Stanley Staple/Nail Gun Elec
Paper feeds crooked
Sounds like a blocked paper path, paperclips , staples , bits of paper etc can drop into the sheet feeder entry and get stuck in the paper rollers.Look and see if you can see anything in there, if not try feeding a piece of thin card back through the printer from the front (ie in reverse of the normal paper travel) be careful and you may be lucky and drive out the obstruction, if not you will need to strip it down to investigate further
Jan 31, 2009 | Epson Stylus 880 InkJet Color Printer
k24674
jasbo
jasbo
