Question about Jenn-Air JJW8230D Electric Double Oven
The oven was continuously beeping last night. Hit everything on the display setup to try to get it to stop. Eventually it shut off all together(the beeping and display) not the only thing that is showing on the display is the clock. Can't get it to do anything?
  • 4 more comments
  • paulacady Jun 18, 2009
    No there was no error code when the display was on. Now the display will only show the time. Nothing else
    can't see anything on the control panel but the time. It won't display or do anything.
  • paulacady Jun 19, 2009
    How can I tell if I need to replace the glass touch board or the control panel inside?
    Will this test work for Jenn Air model JJW8630DDB? The glass touch panel and the EOC are both very expensive and can't be returned once ordered, so I want to make sure I am getting the correct part.
  • Michael Masters
    Michael Masters May 11, 2010
    Has the baking controls and preheat command been Nullified?
  • Michael Masters
    can you see an error code on the display?
  • 6,784 Answers
Ok. this is a control fault. the chip set is damaged. this will usually happen when there is a surge or power failure during a storm or faulty transformer on the outside pole. you Will need to replace this damaged Electronic control board if possible . it has failed.
You can confirm my diagnosis by cutting the power to the oven for 5 minutes. this will reset the control. if the oven continues to react this way with the constant beeping and, non action, this will confirm major control failure..It is possible that this reset will recognize the program and fix this fault but, normally, a fault of this nature will require the replacement of the Oven control board.
Posted on Jun 18, 2009
  • 1 more comment
  • Michael Masters
    Michael Masters Jun 19, 2009
    This simple test will
    help determine whether the EOC (Electronic Oven Control or Clock) or the
    touch pad is defective.
    Some models incorporate the touch pad in to the ERC as a single
    assembly, in which case this test is not necessary. Simply replace the EOC
    (Clock).
    Follow these direction carefully.
    1. Disconnect power to the Oven (unplug the oven power cord or turn the
    power off to the oven at the circuit breaker). It is very important that
    the power to the oven has been disconnected, so please double check
    before continuing.
    2. Gain access inside the control panel.
    3. Disconnect the touch pad (also called keypad or membrane switch) ribbon
    from the EOC.
    4. Make sure there are no lose wires, or anything else that may cause a
    short when power is turned back on. Assemble the control panel back the
    way it was.
    5. Turn the power back on.
    6. Wait for at least one hour to see if the beep code comes back (usually
    accompanied by a error code in some models).
    7. If the beep code comes back, replace the EOC. If it does not, replace the touch
    pad.
  • Michael Masters
    It will work. follow the steps carefully.
  • Michael Masters
    This test is universal.
What is the cause/fix for error code F97 on GE double ovens?
The main control board for the oven is fried.
Jun 05, 2018 | GE Ovens
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
F3e2 error
Oven keeps beeping:
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
My oven has been beeping for the last couple of hours. My son pushed bake and put the temp up to 425. After it preheated, it started beeping and F1 is showing on the display. I have tried everything to...
you can first try to reset the curcuit breaker
flip on and off
if this does not help
usually an f1 error is your control board
what is your full model number from inside the oven?
Apr 22, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Reprogramming the oven
Link to the timer guide for the oven in english. Should have everything there:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318200181.pdf
Aug 23, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Whirlpool GBD307PDS Electric Double Oven
I fixed my problem by disconnecting the control board, cleaning all the contact points (including the ribbon cable) with alcohol and reconnecting everything as tight as possible.
I did notice that one of the contacts had become very corroded, so I scrubbed this one for a while. Prior to this I had done some selective unplugging and replugging (ribbon cable in particular) to no avail (each of these attempts powered on to beeping and no display).
Not a fancy solution, but it did work!
Nov 30, 2007 | Whirlpool GBD307PDS Electric Double Oven
Jenn-Air JJW8230D Electric Double Oven Logo
457 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
