Question about Dell 5110cn Laser Printer
Error code 093-932
Shows replace toner cartridge even after toner cartridge was replaced
Teckies
  • 226 Answers
SOURCE: toner install error
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section21.html#1091115
basic troubleshooting for your printer
Posted on Jan 29, 2008
Corysf62
  • 188 Answers
SOURCE: Yellow toner will not print
If you let the yellow toner get to the point where the toner cartridge was totally empty, there is one thing you can try which may help. From the "menu", select "maintenance", then go to "clean developer" and choose the yellow. The machine will then churn for a few minutes. What happens is there is a tube that moves the toner from the toner cartridge down to the developer unit ( which is behind the imaging drum). If the toner was allowed to totally run out, there is an area of the tube which may have little or no toner in it. Each time you print, there is a spring auger within the tube that draws the toner to the developer. By running the "clean Developer" it turns the auger and re primes the tube.
If this does not fix the issue, and you have replaced the imaging unit, then the yellow developer is defective and would need to be replaced. This involves quite a bit of work and is not considered user replaceable.
Posted on Oct 01, 2008
dan231
  • 236 Answers
SOURCE: how do you replace the toner cartridge on a dell printer 1110?
Here is the manual for this printer.
You should be able to pull down on the front cover and pull out the toner.
Posted on Dec 08, 2008
SOURCE: after replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Posted on May 14, 2009
onynn
  • 5 Answers
SOURCE: wrong cartridge 093-982 cyan toner unsupported
are you using a dell-branded toner cartridge? if yes, then you should replace the toner cartridge sensor and machine control unit (MCU). if no, you can enable the non-dell toner mode on your printer's operator panel. how? press menu, down until "configure" & press select; down until "maintenance" & press select; down until "non-dell toner" & press select; down until "on" & press select.
Posted on Sep 09, 2009
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Why is my Sharp AR 5618 showing F2 subcode 64
I am unable to locate a manual for your model but F2-64 on most sharp machines refers to a black toner supply problem. If you have recently replaced the black toner there is a chance the toner within the cartridge could have compacted & blocked up. If you have a replacement toner cartridge try replacing it, first having completely powered off the machine, replace the cartridge then power the machine back on. If you haven't got a replacement, remove the toner cartridge & gently tap & shake the cartridge before replacing. Again completely power off the machine to reset the error code.
Hope this helps.
Dec 11, 2014 | Sharp Office Equipment & Supplies
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Hp clj 2025 cleaning
I had the same problem and it was the pick-up roller that was at fault. You can buy a new one for less than 20GBP or do what I did. Take the old one out and reverse the rubber. There are plenty of online tutorials on how to change the pick-up roller - the first one you remove. It's a two minute job. Reversing the rubber is easy. Just prize the inner clip out of the roller and put the rubber back on with the shiny side out. It worked first time and no more print errors. HP CP2025 How to Replace the Pick up Rollers and Separation Pad
Jan 20, 2014 | HP Office Equipment & Supplies
GD EVENING SIR WE HAVE SOME PROBLEM IN MY PRINTER THEY ARE SHOW THIS MSG( HEWLETT PACKARD) AND SECOND ONE IS (10.1000 MEMORY ERROR ) THIS TYPE OF ERROR ARE SHOW ME THE PROINTER SO PLS SOLVE THIS ERROR...
the 10.1000 is a problem with the toner cartridge. The printer cannot read it. It might be caused because: A. the toner its generic. B. the toner its defective or C. the cartridge reader is defective. The last one is very rare, so I bet its the cartridge. Try to get it replace
Aug 27, 2010 | HP LaserJet M1522nf Multifunction Printer...
I have an older Sharp AR-168S printer with U2-40 error code.
U2-40 CRUM communication error
Detail-Toner cartridge CRUM data read
error
Cause-A toner cartridge of a different
destination is installed.
EEPROM trouble
Check the destination setup.
Toner cartridge CRUM PWB trouble
MCU PWB trouble
CRUM connector disconnection
Check and
remedy-
Install a specified toner cartridge.
Check the SIM 26-6 setup.
Replace the EEPROM.
Replace the toner cartridge.
Replace the MCU PWB.
Check connection of the CRUM
connector.
Execute SIM 16.
Feb 09, 2010 | Sharp Office Equipment & Supplies
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Dell 5110cn Laser Printer Logo
109 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
