Question about Canon Pixma iP3600 InkJet Photo Printer
Canon inkjet ip3600 black ink printing out purple
Just replaced new black ink cartridge, however when I came to print off my images the back areas were coming out purple, how do I fix this?
  • 3 Answers
SOURCE: Canon MP500 Printing Problem
I had same problem today. Removed print head and bathed it in alcohol for half an hour. Then I removed the two screws underneath and used a syringe to squirt alcohol into the ports and clean. I noticed clumps of ink coming out (i guess some ports were blocked). I then dried the head and reinserted and reinstalled ink tanks. All looks good so far- black printing again and printed test patterns all look correct. Good luck.
Posted on Jan 15, 2008
Joed911
  • 4338 Answers
SOURCE: new cartridge won't print
  1. Make sure you removed the tape from the ink cartridge.
  2. Press the <Menu> button on the printers operation panel.
  3. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  4. Press the <Set> button.
  5. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  6. Press <Set>.
  7. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
daryn720
  • 113 Answers
SOURCE: black ink cartridge is leaking and black line is running down back of page
YOU CAN TRY PULLING THE CARTRIDGE OUT AND WITH A CLEAN , VERY SOFT CLOTH , CLEAN THE HEAD GENTLY ....SOME CARTRIDGES ARE JUST FAULTY ....HAVE YOU TRIED RETURNING IT OR GOING TO CANON SITE AND TROUBLESHOOTING ?
Posted on Jun 02, 2009
  • 37 Answers
SOURCE: Canon PIXMA IP3600 Service error 6C10, and doesnn't print at all
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
  • 328 Answers
SOURCE: The black print won't print, but colour does,
your black ink cartridge got bad sprayer nozzles now you gotta replace it
and why the other color one is not bad yet cus printer as will known will depend on black ink far more so the black cartridge is heated up more times
Posted on May 27, 2011
My Canon ip3600 has full ink, there is paper in the tray. It will print the page I want it to print. However, there isn't any ink / text on the pages that are being printed
It sounds like either the ink cartridges are clogged, or if you've installed new ones, it could be you forgot to remove the tape that covers the ink jet on them. If clogged, you can use alcohol on a Q-Tip to clean the jets.
May 06, 2011 | Canon PIXMA iP3600 Photo Printer
Black is not printing
Try this to unclog printhead.
take out cartridge, locate the hole where ink goes trough, put a can of compressed air and blow it.
put some paper under the printhead to catch ink.
Jan 14, 2008 | HP Business Inkjet 1200dtn Printer
Hi there I have the original canon cartridges in the printer and they all have lots of ink in them, but suddenly when printing the 'black' parts of a photograph looks purple. But when I print text in...
When you are printing a photograph, the back is resultant of combination of RGB but when you print a latter of document it usages only the black ink. So since the black is properly printed when it's combining RGB that means any of the color is low on ink. Replacing the color cartridge will solve the problem for you.
Mar 15, 2011 | Canon Pixma iP4500 InkJet Printer
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The dont know how to switch the ink cartages
The large black ink cartridge is used for printing text and other general black printing. The small black cartridge is used when printing graphics and other fine details. Each cartridge feeds to a different part of the print head, which is used for different purposes.
May 27, 2009 | Canon PIXMA iP3600 Photo Printer
IP90 stopped printing black
if ink is ok than have to change print head for black cartridge
Dec 16, 2008 | Canon PIXMA iP90 InkJet Printer
Prints mostly purple & black
After long uasge the printheads can become clogged and need to be replaced.I buy my replacement print heads on Ebay,but I suggest you compare prices and shipping before you buy.
Jul 20, 2008 | Canon i860 InkJet Photo Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Printing in black "fuzzy"
have you replaced the ink art with a new one?
if you have time to replace the print head.
Dec 13, 2007 | Canon i860 InkJet Photo Printer
Problem printing with HP Business inkjet 1200
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
Oct 28, 2007 | HP Business Inkjet 1200dtn Printer
Canon Pixma iP3600 InkJet Photo Printer Logo
26 people viewed this question
old marine
old marine
