Question about Toshiba E Studio 2330C
Call for service
Also said reboot copier
    Champion:
    New Friend:
  • Toshiba Expert
  • 236 Answers
Need error cord
Posted on Jun 26, 2016
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
What is the service code
There is no service code.
To reset the copier press and hold 0,8. button and switch on the copier.
enter 690 press start button
enter 2 and press enter key on touch screen.
once the reboot massage apears switch off the copier and switch on.
Mar 29, 2014 | Toshiba E-studio 230 Multifunction Copier
Rebooter
The problem is in the fusing unit,fuser warm up error.Enter in the service mode:Press utility key Meter count key introduction 00000000 press enter select trouble reset.
Jan 24, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
SERVICE RECOMMENDED FOR IQC
If just to clear the message:
Enter 08 mode by pressing 0+8 keys and ON the MFP
Enter "000" and press START.
Reset the value shown to "0". Reboot machine.
Mar 08, 2011 | Toshiba COPIERS E-STUDIO 520 Copier
Toshiba copier studio350 error code c470
(c470) - IH initialization or IH power voltage abnormality: The AC input is not applied to the IH control circuit normally, or the input voltage is too high/low.
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press enter. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Sep 16, 2010 | Toshiba e-Studio 350 Copier
COPIER ERROR CODE C470
There is no C470 code but if it is in that range it is likely a fuser Call for Service.
You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Aug 31, 2010 | Toshiba E-STUDIO 850 Copier
Error c477
There is no C477 call for service on an e-Studio 520. If it is in that range however, it will likely be a fuser error. You can try going into (08) mode by holding 0 and 8 while turning on the copier. Once the copier starts up key in 400 and press start, input "0" and press interrupt. Try rebooting the copier, if this doesn't clear that call for service then you are going to need to get work done on your fuser.
Aug 24, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
Error e000008-0001 system will not reboot
Hi, E008 is a fixing roller service life error.
You would have to have the fixing assy repaired or replaced,
I have a good used one contact me if you are interested
ultimate_sacrifice@msn.com
If you need the service manual to troubleshoot it yourself you can get it here
http://www.techmanualarchives.com/canon-ir-c3100_3170-service-amp-parts-manual-25168.html
Feb 05, 2010 | Canon ImageRunner C-3170U Copier
Service code problem
This is a fault of the Printer function's PWB (Printed Wire Board, more commonly referred to as a circuit board).
Hopefully this is a glitch and you'll be able to clear it. To do this press the 'P' (Program) key, then the '*' (asterisk) key, then the 'C' (clear), then the '*' (asterisk) key again (Sequence P->*->C->*. This will place the machine into simulation mode.
Now enter the number 14 on the keypad and press the 'Start' key (the one you normally press to start copies or scans). The machine will clear the fault and reboot. If it doesn't reboot shortly afterwards, press the 'CA' (clear all) key and it should definitely reboot.
If the code returns after rebooting, you need to contact a copier repair technician, as this will most likely be a PWB problem that needs further diagnosis and/or repair.
Sep 18, 2009 | Sharp AR-M237 Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
Toshiba E Studio 2330C Logo
29 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
