Question about Garden
My 38in bolen rider mower won't start - Garden
4 Suggested Answers
  • 32 Answers
SOURCE: what size drive belt does a 38in deck require?
it depends what kind of mower you have, i have a 38'' mower that uses a 14'' belt.
Posted on Jun 12, 2009
  • 6468 Answers
SOURCE: bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Posted on Jul 02, 2012
  • 22 Answers
SOURCE: Bolens push mower Briggs mower when pulling fo
I think that you have a defective gas tank lid that is not venting properly which could pressurize your system and cause problems. Invest in a replacement and hopefully this will solve your problem. The cap has a small breather vent cover [it sort of looks like a small mushroom], this allows air to enter the tank, but keeps air/fuel from going out of the cap. Some mowers use a pressurized system, and I am not sure if Bolens is one of them.
Posted on Sep 21, 2013
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Yardman2003 rider mower keeps fauling the plugs and shuts down why
either your engine is seriously worn or your fuel system needs to be repaired. If the fouling is black and oily its the engine, if its wet and smells like gasoline then you need to start with the aircleaner and go onto carb,
Jul 15, 2014 | Yard Man Yardman Riding Lawn Mower 38in...
My Yardman 13.5 hp Briggs rider revs up and sputters, revs up and sputters.
Does this engine have overhead valves. If yes they need to be checked for proper valve clearance. The engine must be cold to check this.
Sep 24, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Bolens 4.5hp mower won't start
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
Yardman lawnmower stuck in gear. Won't start.
go to https://houzz.com/ type in mower stuck in gear they will give you the answer
Apr 08, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Bolens Q683H 8 speed lawn tractor will not go into neutral.
is the neutral safety switch located underneath the riders seat on this machine being depressed fully to make connection or could this switch be bad,if its bad the unit will not start,because the seat,transmission switch,and start circuit are in series and one that isn't closed(as in a switch) will not pass current to the start circuit
Apr 26, 2010 | Garden
Garden Logo
11 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
