Question about Swintec 2640 Electronic Typewriter
When i turn on typewriter I get a continuous beep
  • Swintec Master
  • 3,594 Answers
Look for debris in the carrier area and spray a little WD40 on the carrier shaft.
DickyO
Posted on Jun 23, 2014
2 Suggested Answers
  • 3594 Answers
SOURCE: SWINTEC 7040 TYPEWRITER PLUG IT IN TURN IT ON ALL
If this has been out of use for some time move the carrier back and forth a few times then spraysome WD40 on the silver shafts it slides on.
DickyO
Posted on Sep 29, 2011
Turn on and it has a continuous beep
Most typewriters have a "power on system test" or POST routine. Beeping means that it fails the test. With the power off, try moving the carriage all the way to the left and turn it on. Some typewriters, if the carriage is not right over the left sensor, will fail the POST. Most typewriters will check things like, "Is there a ribbon installed?" "Does the Daisy Wheel home?" and will move the carriage left to right to make sure that the sensors recognize the left and right limits. There are other checks of course, but those are the ones that are easily fixable.
Apr 14, 2014 | Swintec 2640 Electronic Typewriter
Beeping sound
Usually beeps indicate an error either in operation or that the typewriter cannot complete a request or operation due to a malfunction. If the beep is continuous, you probably have a malfunction and should have it serviced.
Oct 05, 2013 | Brother GX-6750 Typewriter
SWINTEC 7040 TYPEWRITER PLUG IT IN TURN IT ON ALL IT DOES IS ONE LONG CONTINUOUS BEEP
DickyO
Sep 29, 2011 | Swintec 7040 Typewriter
Typewriter beeps continually and first and third lights from the bottom right blink when I turn machine on. Beeping stops after 30 seconds or so, but lights continue to blink and no keys work. I changed...
Be sure the printwheel id properly installed, remove P/W & check for dirt and debris in that area. If you have air in a can try blowin out that area.
DickyO
Jan 05, 2011 | IBM Wheelwriter 6 Typewriter
WHEN I TURN THE TYPEWRITER ON , IT STARTS BEEPING CONTINUOUSLY AND DOES'NT STOP TILL YOU TURN IT OFF AND ON A COUPLE OF TIMES
First thing to try is a little shot of WD40 on the 2 silver shafts that the carrier slides on.
DickyO
Nov 20, 2010 | Nakajima AE-830 Typewriter
When the typewriter is turned on, it continually beeps after going through the initialization. What is causing this?
If the printwheel is properly installed and there isn't any debris in the carrier area there are probably broken wires in the wiring to the carrier.
DickyO
Sep 07, 2010 | Nakajima AE-740 Typewriter
Turned on the typewrite and after it goes through its setting, it starts to beep continuously and nothing works! How can we fix this?
Lubricate the mainshaft that the carrier travels on with a 10 weight oil. Do not use WD 40. Wipe shaft with a soft cloth and reluricate.
Oct 29, 2009 | Olympia Mastertype 3 Typewriter
Typewriter just beeps
very common problem, The print wheel homing sensore weirs broke off. you need to take off the ribbon deck. pull weirs from the white plastic sleeve that runs from carrier to main board. fined 3 weirs grouped together ( red, black,green) 1 or more of them are cracked in side the casing or have broke in 1/2. need to resolder them together little tough to do the 1st time. a bunch of sen sores came out with to hard of a weir making them brake premacherly
Jan 08, 2009 | Nakajima AE-710 Typewriter
Beeping
It most likely beeping because it cannot make its resetting movement. That is,it cannot "find-out" where its left margin is. There may be something hindering the actual movement of the print carrier. Check inside the typewriter by lifting up the top cover and move the print unit by hand. It should be able to move from the left to right-hand side of the typewriter unhindered. The shaft that the print unit moves on should be clean and it may have gathered dust etc,so give it a wipe with a clean cloth (lint free) with a small drop of light oil on it.. Replace the top cover and switch on the machine
Nov 05, 2007 | Nakajima AE-740 Typewriter
Swintec 2640 Electronic Typewriter Logo
85 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
