Question about Sony Cameras
Sony cassette deck tc-wr445 problems
Belts all intact but cassette won't play
petraman7
  • 1175 Answers
SOURCE: Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Posted on May 05, 2008
SOURCE: Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Posted on Jul 11, 2008
welcomejee
  • 10594 Answers
SOURCE: NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Posted on Dec 25, 2009
SOURCE: Sony tc-wr535 won't eject. Tape stuck. Won't play
The problem, according to messages on your site, is that the belts are old and have stretched. There is a great step by step tutorial on www.Instructables.com with pictures and all. Parts are not too hard to find on search engine. Looks like less than $25 to fix.
http://www.instructables.com/id/How_to_replace_the_belts_on_a_Sony_TC_WR535_Dual_C/
Posted on Jan 18, 2010
mybradley7
  • 242 Answers
SOURCE: Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Posted on Jun 28, 2010
Sony tc wr445 tape won't move
It may need new belts but also the transport may have dried up grease which can be costly to take apart and regrease.
Sep 04, 2014 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Ive got a Sony tc-ke600s cassette deck which a wobble in the sound when playing or recording and would like to know what I can to so solve this problem? Thanks Mark
Chances are it will be the belts which will be either worn or loose. To replace them make a note of how the fit, take photos if that helps. Once off measure the diameter in mm (you don't need to be spot on with it). Then enter "Cassette drive belt ??mm" into google.
Sep 14, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Sony tc-wr535 won't eject. Tape stuck. Won't play cassette on either deck A or B .makes noises but won't FF or play, gets stuck and wont eject. Will belt conditioner work? What do I use?
Jan 16, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Apr 29, 2008 | Sony TC-WR565RM Single Cassette Deck
Motor plays at a very slow speed
capstan belt may be failing. check this by removing lid and touch the capstan flywheel when running. if it is easily stalled/slow to come up to speed and or the belt slipping badly then belt will require replacement.
Oct 14, 2007 | Sony TC WE435 Stereo Dual Cassette Deck...
Cameras Logo
63 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
