Question about Polar F11 Heart Rate Monitor
What batery does a FS2C take I need to replace my battery in a FS2C. What battery do I need to get?
My cordless phone Gigaset A49H is working well. I need to replace battery. Can I use AAA Ni-MH 900mAh 2V battery
if the volts of the old batery is the same with the new u can use it...no matters if the old battery was from lithion only or nikelioum / kadmium . u can use nikelium/magnisium batery too all rechargable are (sry for bad english)
Sep 28, 2015 | Siemens Gigaset A49h Cordless Phone...
Change or charge battery
Hi, depending on what happens when the batery is fully charged, does it go flat aftera day or two or does it stay charged? If it keeps going flat take it to a battery centre to test the amps that the batery makes. I f the amps is out the battery is dead.
But
If the batery is fine after charged and the amps is correct and the bike still makes the batery flat.
Then you have to replace the Stator and the magnitor.
Dec 09, 2010 | Yamaha YZF-R1 Motorcycles
I have an m5310 and i have troubles with the battery charge i bought a new battery but is still the same , i plug the notebook to the ac power and batery start to load (the front green light is on ) after...
Try to perform power drain on the motherboard.
heres the steps:
take out the battery
unplug the power adapter
press and hold power button for 30secs
put the battery back in
plug in the power adapter
power on the computer
if same issue will happen then you need a battery replacement.
May 21, 2010 | E-Machines M5310 PC Notebook
Polar fs2c battery replacement
Many people replace their own batteries but some of them have problems with replacing the backs and finding (for some unknown reason) the watch no longer works!
I advise you to take your watch to your nearest authorized dealer and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 03, 2010 | Polar FS3 Heart Rate Monitor Watch
Hi - is the battery on the Polar FS2C changable - and if so how can I do it?
Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
Feb 28, 2010 | Polar FS3 Heart Rate Monitor Watch
My desktop compaq sent me a message stating that the time & date is not set and may b a result of a loss in batery power, ask m to correct date and time and if mesage persists I have to replace the...
you need to replace your cmos battery, you need to open up the casing of your computer. you need to look for the coin cell battery on the motherboard, there shoulb only 1 there, so you cant miss...
Feb 17, 2010 | HP Compaq Business d530 PC Desktop
Battery problem.
you must need to replace your batery.Do not wait the batery to be exploded before you replace it.
Nov 22, 2009 | BenQ-Siemens EL71 Cellular Phone
I need to put new baterys in my key fob for my renault megan coupe 1998 can i just swap the baterys at home thank you
go to any auto or batteries stores and they will replace the batteries for u.....or u can do it yourself....
Mar 07, 2009 | 1986 Renault Sport
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Dec 23, 2008 | HP Compaq Business NX9110 Notebook
Polar F11 Heart Rate Monitor Logo
46 people viewed this question
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
