Question about GE (PSS26MSRSS) Side by Side Refrigerator
Cannot get handle off GE side-by-side GSF25TGTA WW to tighten screws underneath
  • 111 Answers
The handles have two caps one on the top and one at the bottom , just remove them with a small screw driver and you see the screws
Posted on Jun 18, 2009
Problem with the GE JVM1350BW/WW/AW/SY Microwave Oven The handle broke off completely. Can it be replaced? Doesn't look like there is way to get back of door off to replace/repair handle.
The inner plastic ring has to be removed. That WIDE ring is called the choke. Use a flat bladed screwdriver and a knife blade to get it free. It has tabs on the inner side and the outside that have to be unlatched. Once the choke ring is free you will have access to the screws.
See this video:
Sep 24, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a ge side by side refrigerator model gss25qta with a loose handle. there is no trim or cover piece. Just the handles on the face of the door. How do I get to the screws to tighten them?
1. off the upper and lower ends with flat plastic or apadded flat head screw driver so as not to scratch your stainless steel. Atwisting wrist action will suffice. 2. Now the screws are exposed, you can re-tighten them. 3. Replace the plastic covers starting with the base whichhas a small plastic the goes into a slot in the main handle. Then glide therest forward and it snaps in effortlessly.
http://www.partselect.com/Schematics/GE/00115279i01.gif
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
How to tighten loose door handle
should be a small access cover on the handle top and bottom pop them open with a flat small screw driver screws should be underneath
Jun 09, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
One handle is loose-how can I tighten it
shoulb be screws under cap on handle remove and tighten that should do the trick
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Handle is loose on GE Monogram Model# ZFSB27DAG SS. How do I get thehandle tightened up? No steps have been taken to fix problem. Stirwin
handle secured by 4 stainless stand offs on each door correct?, i would look closley at the underneath of the standoffs should be a screw to tighten/loosen. . actually lookin at diagram theses are comlete doorskins wrapped around the door itself you might need to remove teh screws on top and bottom ofr door skins and tighten from behind s/s skin
Mar 04, 2008 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Ge Profile side by side
Pop off the trim piece at the bottom. Mounting screw is underneath
Feb 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
151 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
