Naw work on display 432 mhz bat tk 208 it is vhf
SOURCE: Motorola and Kenwood compatibility....
Hello!! First of all, any radio in the right frequency will work with any other, to work just need the following features: -Frequency, 154.700 which is correct as you said. - the Squelch code, this could be PL or DPL. The XV2100 has a table of codes that you can try, as you dont know this code form the Kenwood, you will need to check one by one. If you have the chance to send the Kenwood to some to "Read" the radio parameters( freq.,Code, ETc) you can look those parameters on the XV. Hope this can help, any comments [email protected] Good Luck
SOURCE: communication not good &battery cannot charge
If your area is big or has a lot of concrete, then you will need more then just a few cheap radios from thailand, Given range info from broshure is always meant above flat area - not inside building
SOURCE: VHF/UHF RF Power falls to Zero when the Auto ATU
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
